1 - 20 of 23 Posts
We had a steady drizzle for past 2 days, my yr old wiper blades are smudging up the windscreen like there's no tomorrow. Add dark asphalt and poor headlight to that mix, and I had to squint my eyes just to struggle my 15 mile commute home, still having a headache.grrrrrrr
Any recommended windshield wipers for the E39? Need them BAD!!
Reactions: bimmerule
Personally I like the OEM replacement inserts instead of buying a whole after market frame. I've tried the OEM "supplier" inserts from Pelican but they're not quite exactly same and have a lock block in the track which doesn't fit into the tabs for the stainless steel stiffeners well or the frame tabs, but can be forced in. I think I may go back to the dealer OEM inserts or try the ones AGM5 suggested next.
I have a few closeout sets from NAPA I snagged if you wanna try a set. They work fine so far for me...in SoCal. PM me, the shipping cost may be a deal breaker though.
Hmm same brand as ones on Pelican web site. (SWF) Which work but have a slightly more tricky mechanism to hold them in place than the ones sourced from the dealer.
the only difference that I found between the ones from Autohausaz and the old dealer parts was that the aftermarket do not have the steel supports. Because of this you get to reuse your current steel bits. Nothing too tricky here.
On a side note; I was talking with my parts guy last evening, and new inserts are available from the dealer. However, they will not fit the "old" style blades. So, if you bite the bullet, and buy the $65.00 (pair) new style blades, you can continue to get new refills at the dealer.
I also use Napa brand. I bought them 3 years ago. No issues. The key to long lasting blades is to keep the rubber clean and the windshield clean. I also rain-x my windshield, but even when the protection is wearing away the wipers still work fine.
I suggest (unless your blades are ripped) to run an alcohol wipe up and down each blade to clean the crap off of them, or even an old microfiber cloth that you won't mind if it turns black. Then hand clean your windshield (inside and out) with glass cleaner. My bet is you will be amazed at the difference. It is possible your blades are too far gone, but only being 1 year old, they are probably savable.
FWIW, I searched OEM part number 61619070579 (from Realoem.com). This is the part number for the pair. BMW of Morristown has them for $27.37. I don't know what actual brand this is (Bosch?). Probably cost $10 to ship.
How are the results compared to OE fill, streak free? I have the same in my shopping cart, ready to pull the trigger. Forecast called for rain 5 out of 6 days, this is driving me nuts.
I think you're right, I noticed when I use the windshield wiper fluid, the first few swipes are the worst. Maybe I should switch the wiper fluid too?
If you're just using the basic blue stuff then it's fine. I can't comment on other products as I've never used anything but regular blue fluid. I miss the days when I worked as a mechanic at a dealership and I could fill my own washer jugs to bring home. That in itself is nothing special since the fluid is so cheap, the cool part was that I could and did change the ratio of water to concentrate. Made for some pretty aggressive window cleaner in the winter! haha.
Anyway, It sounds like you're just dealing with dirty surfaces. Do a through cleaning of the window and blades and if nothing else it will help get you through this rainy period before you buy something else.
These blades are awesome. I just threw them on a couple weeks back and they're perfect. Silent, uniform clearing wipe.
Only thing better would be to add e60 windshield spray nozzles. The wife's QX56 has that style, they shoot a spread instead of a stream. It's sad how much I enjoy using them.
They are dead silent like the factory blades and clean the window perfectly. No complaints here.
BMW's OE wiper blade set (61-61-9-070-579) has a new lowered MSRP of $40.13. And that's for a set.
The OE inserts (61-61-8-217-711), however, has an MSRP of $18.44 each...
1 - 20 of 23 Posts
