I have an e39 528i that has a window regulator problem. I believe the regulators are the same, across all e39 models.
I have corrected the original problem of the window not raising or lowering. The wire had slipped off the pulley at the bottom and its attachment at the top was kinked.
Upon reinstsllation. I noticed that the motor seems to continue running after the window has reached the extreme of its travel. This isn't a problem when opening as there is a rubber bumper to absorb the shock. When closing however, the aluminum clamp that holds the sleeve in which the wire travels gets bent by excessive pressure. I thought the glass reaching the top signaled the motor to stop running as resistance increased so I installed everything completely before operating the window by activating the auto-close feature.
My question is; What signals the motor to stop turning after the glass is fully up or fully down?
When observing the mechanism with the door card off, its obvious this signal isn't being received by the motor. The damping spring when the glass is fully closed is completely collapsed and the run of wire that will pull the glass down has slop. This slop, I believe, is what allowed the wire to jump off the pulley.
Right now. I'm thinking I need a new motor to correct the problem. That is, the existing motor is not responding to an increase in effort that should signal it to shut off.
