1 - 8 of 8 Posts
Hello again! I want to flush out the power steering fluid and my car has sls supsension and its a bit soft and squishy.
will changing the fluid work?
The SLS does not leak nor does the power steering just want to put new fluid.
i purchased bmw fluid.
932370
The SLS system is specific for Pentosin 7.1 which is a non-synthetic. Pentosin no longer makes 7.1 but I believe there is another company making the 7.1. Do not use anything else!
thank guys. i spoke with bmw tech. and I asked him this question and he said this is comparable
Many BMW technicians these days are not familiar with vehicles of this vintage. Do some research and verify that what you have is compatible. If you put anything other than what is specified you run the risk of damaging the system.
your absolutely correct. and thank you for the help i will follow up again on monday i did ask the tech twice but its true the techs are not always knowledgable on everything
Yup, Febi Bilstein makes the 7.1 green non-synthetic fluid.
1 - 8 of 8 Posts
