1 - 8 of 8 Posts
Hi All:
I currently have Brembo brakes on my 19" AC Type III. (F 19"X8.5" / R 19"X9.5")
Howerver, I want to buy a set of 18" BMW factory wheels (M-Parallel) for my E39. (F 18"X8" / R 18"X9.5").
I would assume many of E39 M5 owners have install the similiar Brembo rotors/calipers on thier beast with OEM 18" wheels.
I would like to get a conifrmation to see if the OEM 18" wheels will fit on my Brembo rotors without any problems.
Here are my current 19" wheels on Brembo:
Thank you and I appreciate your input.
Jimmy
IIRC, the M Parallel wheels in 18 in. should clear your brakes.
I remember a post by Dave Z mentioning that the M Parallel wheels in 17 in. cleared the StopTech kit for the e39, for people with a BBK that were looking for a spare.
Maybe Dave Z or someone else could chime in and confirm this.
Here is the post I was speaking of, if these are the wheels then they should work in 18in. since they clear a BBK in 17in.
DZeckhausen said:
You can get a 17" Style 66M wheel and use it as a spare. It's going to kill your trunk space, though.
I called Brembo and they say 18'X"8" should fit, but I'm not sure it would clear the caliper. The one I'm getting looks more like this:
M5 Extraordinare!
You actually would probably need to get a spacer if you're going to use these wheels with the Brembo brakes. Stoptech front BBK is the only one that will actually fit under the stock 18" wheels. That's why I chose Stoptech over the Brembo at the time. DZeckhausen would know for sure. Send him a PM.
atomic80 said:
You actually would probably need to get a spacer if you're going to use these wheels with the Brembo brakes. ................. QUOTE]
It is it because the Brembo calipers are located slightly outward?
atomic80 said:
You actually would probably need to get a spacer if you're going to use these wheels with the Brembo brakes. ................. DZeckhausen would know for sure. Send him a PM.
Thanks, I already send him a e-mail
Further thoughts? Thanks buddy! :)
Dave Z is out until at least Monday (unless he has his PDA or wireless laptop at Sebring!!!).
Speaking of brakes, is there any real difference between the GT rotor/caliper combo offered by Brembo and Dinan brake kit?? :confused:
1 - 8 of 8 Posts
