1 - 6 of 6 Posts
Translation for those out in the colonies!
Fettle-, to fiddle with, continually adjust, tweak, hone, improve. Fettling-to annoy the wife, wasting time in her eyes.
Anyway, car has been 'pinking' on and off, with slight loss of power and occasional rhythmic hissing/ticking noise. MPG has also been down.
So I was under the bonnet checking levels and I noticed the breather pipe on the flying saucer thingy? Was not fully locked in position. I pushed it fully on, heard the click. Car now back to normal!
Get out there guys, go right now and fettle!!!!
Reactions: drinkmaker
Hi Jim
As per your instructions, the PLCD cured the SMG issue, saving me ££££ in labour charges and all is good, you sir, are a legend.
I think the flying saucer thing is the SAI valve (adds extra air to exhaust at startup). The line would be a vacuum line, so you basically had a pretty major vacuum leak.
Now that I read about this... My beast's Air Injection Hose is also bad, the locking end of the hose is pretty badly worn out, I am guessing it is due to the heat...
But I do have a question... What exactly does that hose do? and if we have a leak there, what are the symptoms?
If you can view this link, you'll see the layout of the SAI system.
RealOEM.com   BMW E63 M6 Pollutant reduction pipes
The hose into the valve comes from a blower motor, that runs on startup. It injects air into the exhaust to help with combustion through a cold exhaust.
I'm not as familiar with the way the S85 works, but in the older Land Rovers (discovery2), an SAI fault will set a check engine light, as the ECU monitors the O2 sensor, and watches for a change in oxygen level when the system runs.
Matt
1 - 6 of 6 Posts
