So I get in the car late this afternoon and as I begin backing out of the garage, I hear "crack/pop" and the car shakes just a touch. Feels exactly like when pads lightly seize/rust to the rotors after parking/sitting a while following a drive in rain. No big deal, although this sounded a bit louder and the car shook slightly more than normal as the pads "let go" of the rotor. I think "well, last I drove was in snow/ice/salt, so maybe that's why the pads seized to rotors a bit more." Uh, no...
I keep backing out slowly and hear "clang" and then a horrible noise from right front...like something scraping/rubbing hard on the brake backing plate/dust shield. Get the car out of the garage bay, walk around and tire/wheel are tucked way up in wheelwell. I look in garage where right front wheel sits and there, resting comfortably on the ground is the lower coil of my Dinan spring. Oh come on!
Called Dinan, they looked up my order from 2007 and told me to send them a couple pics. 15 minutes later, Dan McNiff (warranty tech) at Dinan calls me back and tells me a new coil is on its way and I will have it tomorrow. He couldn't have been more helpful.
Spent the next hour tearing everything apart so that it's ready to go when the new spring arrives. Why does this only happen when it's 20 degrees outside, I'm losing daylight fast and the car is disabled such that I can't pull her back in the garage to work on it?
Oh and thank God I bought an impact gun over the holidays, otherwise the top plate locking nut would still be seized to the strut! That thing is awesome!
Should get to install on Friday...hopefully I won't freeze to *****...and alignment on Monday if all goes to plan.
Why can't these things happen on a nice sunny Spring day instead?
37.5 KB
261.1 KB
249 KB
386.6 KB
278.8 KB
