1 - 20 of 27 Posts
Hey,
Who did buy MAF's from Continental Imports?
I got mine today, but I noticed the number is not what it's suppose to be.
Even if I ordered as specified in another thread, I got my MAF's with following number : F 00C 2G2 032
Can somebody bought MAF's from Cont-Imp verify if they have the same Borsch number before I mount mine into my dear beast ?
/Stigh
AFX said:
Hey,
/Stigh
Here is info from prior posts:
Originally Posted by Anzir
F 00C 2G2 029
Total bill for parts: $308!!!!! That's for 2 units!
Any questions on the part, just call Chuck at Continental Imports at 352-377-6604. He said he'd be more than willing to help anyone out who has questions! If anyone is in the Gainesville area, I would definitely recommend them, albeit they put a good amount of miles on my car with the diagnosis and testing of new parts, but I'm still pleased as punch. They give a good amount of detail as to what is tested, what they are looking at.. 1000% better than any dealership I've been to. And highly competent at that.
Per Anzir's great info, I called Chuck & purchased 2 of these inserts just now.
The actual part # is F 00C 2G2 INS ( INS for "insert" )
He assured me that they are the direct Bosch part # we want.
Vic
Vic
I just checked my invoice and that's the part number that they put on it. I was reading the number straight off the MAFS insert when I first reported it. Glad the info helped!
gsfent; I know, I know....
On my invoice, it says the same.
BUT; the number on the part itself does not state INS or 029 (which is the original three last digits).
Thats why I would like to know if the received MAF's had different number printed on them vs. the invoice.
/Stigh
/Stigh
I see. Well, I doubt if the part would say "INS", that would simply be a part number code to indicate "insert" and tell the parts person it is not a whole MAF.
The part number is different. Try getting onto www.realoem.com and see what part numbers com up for the MAF. The discussion indicated it cross referenced to the VW 1.9 turbo diesel MAFs so look at those too. Also, phycially compare to your old ones. If they look identical and have the came connectors, I would probably hook them up. Maybe someone else can chime in.
AFX said:
Hey,
/Stigh
Can you let us know how the installation was and if there was an improvement in performance? I'm at 50,000 miles so may need to replace soon.
Thanks.
When I read the original part number, it was off the old MAFS that they took out of my car... i'm hesitant about taking the new ones out to see the numbers since they're working so well.. :p
Discussion Starter · #7 ·
Haha.... Well; hopefully I get my bimmer back tomorrow; it's at the dealers shop as a result of me sending an email to the norwegian distributor regarding my problems.
They now will check camshaft sensors, vanos, compression, spark plugs, o2 sensors... I have demanded a solution to the problem(s) !
When I get it back; I'll just put them in, close my eyes and listen to the beautiful "roaaar" of the V8 igniting... Then take it for a test spin...
I'll keep you updated :wroom:
AFX said:
Hey,
/Stigh
I got them, made the car go like a banshee again.
It is awesome no more low RPM stumble, nothing.
I just ordered mine yesterday, though I think the influx of calls from us has prompted them to raise the prices. I was charged $158/sensor bringing the total invoice to $332, not $308. Just info for everyone to know and stay updated with, still MUCH cheaper than new horns from the dealership though!
:cheers:
Sean
hmmm Keep your eyes open.
:cheers:
Sean
:cheers:
Sean
Did the price include a BMW CCA discount? Most dealers give 10%or more. If you have a company with a car sounding name, they will usually give you a trade discount of 15-20%. At $150ish each, it might already be included though.
AFX said:
Hey,
/Stigh
I'll take one out tonight & read off the part number -
As I mentioned in the prior MAF thread - the difference is outstanding.
Forget cleaning ( I did it correctly 3 times with recomended spray cleaner ) which initially made a marginal improvement, but degraded back to the prior symptoms within days - this is what will do it.....
Will get back later.....
Vic
Have you run the OBC test to see how many L/H you are flowing?
:cheers:
Sean
Well 332 versus 600.
Discussion Starter · #15 ·
Well; my new MAF's from Continental sure gave me the improvements I hoped for, and much more! Never had so much power since I bought the car...
Ordered a pair Monday, should be here (Utah) Friday. Just paid some lame local BMW mechanic $1K to do some diagnostic work and repairs before finding these threads -- he ended up replacing the fuel pump/filter.
Question: When I start the beast in the mornings now (post fuel pump), I still have some bad hesitation and cutting out until the engine warms up. After it warms up, I can still tell the power's missing, which I'm pretty sure new MAFSs will fix. Is the cold hesitation problem (hopefully) related to this too?
Cold hesitation can be many things, including MAFs. Check related thread about checking for MAF flow by using the On Board Computer (OBC). Go to procedure 4 (NR4) and go to test 2. You will see the car measure liters per hour, L/H. At WOT at or near redline you are looking for something around 135.
Good luck. And if it turns out to be MAFs, I would be trying to get my money back from the "professional" who clearly misdiagnosed the problem.
Discussion Starter · #18 ·
Jerry,
For me that does not have a NAV screen; I have found no way to activate this test. I "only" have the little strip bar with info...
I'm not so sure about completely disputing the guy, as beforehand I had bad cutouts under load, and bad air/fuel mixture codes which have gone away since replacing the fuel pump. I did the L/hr test many times over the past two weeks, before and after cleaning the MAFSs myself. The numbers were in the mid-eighties near sea level two weeks ago (visiting relatives in CA), around the same in Utah. Funny thing is, after replacing the fuel pump, the numbers went down a bit! But again, once the engine runs about a quarter mile, no more hesitation whatsoever, but no pull either.
AFX said:
Jerry,
You should still have an OBC. It displays in front of you, below the instruments. Functions can usually be changed by depressing the end of the left stalk (turn signals). I usually have the time setup there. If so, the directions for checking the MAFs should work for you just fine. PM me if you want more help.
1 - 20 of 27 Posts
