1 - 7 of 7 Posts
I want to check my idle fuel pressure can anyone direct me to where the schrader valve is located?
Is that part of the FPR assembly? If so, it's under the driver side floor. If you are underneath the car, you will see a large plastic cover. Remove that and all the fuel stuff is right there. If that's not it, try looking where the evap canister is near the passenger headlight.
That's where it is. Just off of the fuel filter, pretty much directly under the driver's seat.
Is it the same as a GM? I have one that works on my LS powered stuff, I would assume its the same valve.
1 - 7 of 7 Posts
