1 - 7 of 7 Posts
Are the 17" turbine wheels and the 17" throwing star wheels identical underneath ie identical except for the cover pieces?
I am looking for a spare set of wheels (8" front 9" rear) (I have throwing stars on mine) and have seen a set of turbines, but i dont want to drive 200 miles to find they are different.
martin
Discussion Starter #2
And as a follow up question - any idea how I determine if the wheels are genuine BMW parts of some sort rather than fakes?
And I quote "
What are the factory wheel and tire sizes for the E34 M5?
There are two factory 17-inch wheels for the E34 M5, M System I and M System II. Both are a two-piece wheel with a forged five-spoke center and a cast rim covered by an outer cover. The only difference is the design of the outer cover, "turbine" for the M System I and "throwing star" for the M System II. This outer cover is interchangeable between the two M System wheels, making updating form the earlier style to the later style an easy (and therefore common) procedure.
The 3.6-liter M5 is equipped with 235/45ZR17 tires on 8x17-inch M System I wheels. However, for the 1993 model year, North American-spec M5s use the M System II design in the same size. In addition, wider 255/40ZR17 rear tires on 9x17-inch M System I wheels were available as an option in some markets (not North America).
All 3.8-liter M5 sedans built before May, 1994 are equipped with 235/45ZR17 tires on 8x17-inch M System II wheels. Sedans equipped with the optional Nurburgring Package and all Tourings use wider 255/40ZR17 rear tires on 9x17-inch M System II wheels."
FYI it isn't as straight forward as you might think, i bought a set of "turbine" wheels and a new set of "throwing star" covers and centre caps. The covers fitted perfectly but there is no lip on the wheels for the centre caps to clip in :sad3: I ended up removing the plastic tabs from the centre caps and had to superglue them in to place !.
If the covers are bolted to the wheel then they are genuine :) And the "throwing star" part of all the fakes i have seen all go in the same direction so the wheels on one side of the car are going in the wrong direction !
1 - 7 of 7 Posts
