1 - 3 of 3 Posts
I'm looking to replace my left-hand plastic underbody cover (the one that covers the fuel filter), as well as the plastic wheel arch liner.
I'm assuming I'll need to buy new plastic rivets as the old ones will break when disassembling.
Could someone help out with the part numbers for these rivets please, and how many I will need?
TIA
For the wheel arch I can confirm it is part #10 (51478166992) having recently done this work. I needed three of them per liner and they are used where the back outside edge of the liner meets the body. These rivets are one time use.
The rivets/fasteners used on the under body cover are different and CAN be reused, just use a pick or flat head screw driver to pull the center tab out out before you pull them.
1 - 3 of 3 Posts
