whats a "leak down test" ???????
981 3
hello there,
i was just wondering if anybody could explain to me what a "leak down "test is? i have had this term quoted at me but have no idea what it means.... so if anyone could explain what it is, how its done, and where i could get it done i would very much appreciate it.
thanks
zavy.
1 - 4 of 4 Posts
I'm no mechanic..........but typed it into Google..........
http://www.motorcycleproject.com/motorcycle/text/leakdown.html is a good explanation (from a motorcycle forum)
and an extract from some site about 928's.......
A leak down test is where each cylinder in turn is put just before TDC, and
compressed air is applied via the spark-plug hole. The leak is measured as a
proportion of the "leak" of the open test pipe, so a perfect seal would be
0% leakdown.
The big advantage over a compression test is that you can hear where the air
is escaping. There will always be some leaking past the rings, but there
should never be any leaking past the valves, or into the coolant!
Hope its a start............
Mark
:cheers:
hi there,
thanks alot mark for finding out that info...its a great help tp know what a leak down test is now.
all i need to do is find somewhere that could perform this task for me...is it something that most good garages could do, do you think??
thanks alot for ya help
cheers
zavy
Not sure. Maybe more of an engine rebuilder, or perhaps more of an "old school" mechanic ?
I am sure its not an uncommon thing as far as engine fault diagnosis goes.
I'd give a few of your favourite garages a call......
Mark
:wroom:
1 - 4 of 4 Posts
