yes but they dont have the smoked reverse light do they?
could you tell me more about this cold check function? im not sure what you mean?
ahh, you are correct, they do make clear CELIS lights that you could paint any way you please.
the check function or "monitoring" function sends a pulse of current through the tail light (or any bulb monitored system for that matter) so that it can check the lamps function by measuring voltage drop across the system.
cold check or hot check tells you when the circuit is checked - cold = bulb(s) switched off; hot = bulb(s) switched on.
in LED lights, this pulse of current will cause the lights to "blink" every time the LCM performs said check (every few seconds).
this function can be turned off while via coding the LCM.
