1 - 5 of 5 Posts
What is the weight of our stock 18" wheels? I may be slow, but I had no luck when I tried to search.
Oem M5 8" including Tires 21,2kg = 46,64lbs (Nokia NRY something)
Oem M5 9,5" including Tire 23,2kg = 51,04lbs (Dunlop SP8080)
I have new PS2´s on the wheels now but i havent had a chanse to weigh them just yet.
If you want i can try to do it tomorrow or so.
Rims only;
front: 24.7 lbs.
Rear: 25.9 lbs.
This may be a little inaccurate due to the shop scale I used.
thanks to both of you...i was looking for the weight of just the stock wheels.
howler said:
Rims only;
front: 24.7 lbs.
Rear: 25.9 lbs.
Thought I'd done the exercise a while ago. Did a search on 'stock + wheel + weights'. They were pretty close (-0.5 lb) to yours, Howler. Here goes:
http://www.m5board.com/vbulletin/showthread.php?s=&threadid=10043&highlight=stock+wheel+weights
Short answer (using a pretty accurate USPostage scale that's calibrated often):
Fronts = 24.20 lbs
Rears = 25.18 lbs
-Dave
1 - 5 of 5 Posts
