1 - 14 of 14 Posts
As I was using my washer today, it suddenly went weak and water barely squirts out. If I press the intensive action button, it's still weak. But, if I hold down the intensive action button it sprays hard as normal.
The other thing is the headlights no longer spray either.
Both fluids reservoirs are full.
Any clues?
Try looking and seeing if the washer has dried gunk on it. I know one of mine wasn't spraying out washer fluid correctly and when I looked it was gunked up. So I just took a paper clip and cleared off all the gunk on it and around it.
If that isn't it, I'd look at all the connections and make sure there isn't a leak.
I thought about that, but then I wonder why it sprays hard and normal when I hold down the intensive action button.??????
In Memoriam
The headlight washers only spray once in every 5 uses of the windshield spray nozzles when they are used with the headlights on. It's in the Owner's Manual.
Oh yeah, I misread that. I thought it did it every 5 times when 5 is press, but apparently it applies to 6 also. But, I could have sworn it does it every time 6 was pressed.
In Memoriam
You could be correct about "button" # 6, but the manual spells it out.
I just deleted mine...:hihi:
1 - 14 of 14 Posts
