Hello ,1990 3.6 . Had the viscous fan seize and shear off straight through the radiator @ 6500 rpm . Big thud and a dented bonnet . I have since replaced radiator and viscous and fan . put it all together and now have a leaking water pump from centre bearing . so decided to pull it out and replace . I have a snag as I cannot reach one of the bolts . Seems to be behind engine lift bar . Tried to remove this for access to bolt , no luck. Any one replaced water pump and have any tips for me to reach last bolt o water pump housing . Thanks In advance.Trying to keep the faith
