Water in my front headlights ( in the upper part)
6221 11
Hello
For some days i have noticed that the upper part of my headlight has water in it . That part of the headlight should be ermetically sealed , since it won't dry it out with the sunlight directly at it . A guy that works for BMW sais the only option is to change the whole headlight . Any other ideeas ??
I will post a photo very shortly .
Thanks in advance .
1 - 12 of 12 Posts
Bring it back to the dealer, this should be covered under warranty.
YES, warranty, it's covered
+12:cheers: but sometimes you can cure it when you turn your headlight for while and let the water evaporate...
I ran it with the light turned on , but the water is still there . It's like somehow that part wasn't perfectly sealed and water or very humid air got in there . But the same way it entered it should go out , but it doesn't .
Weird as hell .
PS : It might seem like an idiot thing to ask but how do you change the eyebrows leds ??? if i take them off i should be able to get some air in them and just dry'em out ? I checked the manual but it doesn't clarify me .
Thanks for your time .
ya know, im not sure if the head lamp cavaties are vented to dissapate moisture, check that, if they are the vents COULD be clogged !!!
it's ugly...dealer
1 - 12 of 12 Posts
