1 - 4 of 4 Posts
Looking for few random hard to find pieces
EURO Leather lower dash kit - Any color
DINAN high flow MAFs
Quality staggered Muffler delete tips
1 rear wheel 18 x 9.5 style 65
Thank you for any and all help
I have Dinan High Flow MAF's. DM me an offer.
Hello
Thank you for reaching out.
Would you mind sending me a picture of everything you have? There were a few different styles made...
Some for attaching to stock airboxes, some for cold air setups.
Also if you had all couplers/clamps and mafs or if just housings only
Sorry just trying to be thorough so can give accurate offer
Thank you
Hello
Thank you
I may be misreading, but I think you are confused.
I assume you know that the larger Dinan MAF's are simply the housings. The stock MAF's (Bosch mass airflow sensors) are retained (you can go alpha N). The rubber bellows need to be replaced with the larger ones if you are running the Dinan CAI. There is only one version that I am aware of.
There were two versions of the velocity stacks. The very early version included a spacer for the plenum to make the velocity stacks fit. The later ones were done in such a way that the spacer was not necessary.
From experience, the high flow MAF's wont do much without some of the other hardware.
1 - 4 of 4 Posts
