VERY Anvoying noise
1325 11
I've got a noise coming from my front wheel (Never noticed it b4 due to windows being up) 1st Sunny day in Scotland.
It's coming from my front Passenger wheel sounds like a ticking noise (speed related)
God! if i didn't like this car so much i'd be so ***sed off right now.
Any ideas?
Getting the CPS done on Monday hopefully....
1 - 12 of 12 Posts
almost sounds like a rock is stuck in your tire tread.
took the wheel off and you can still hear it.
Ticking noise sounds a bit like a newtons craddle....:eek:oohhh:
tick tick click...
Hi Shamus
My wife's Boxster had the same a couple of weeks ago. I removed the front wheel, and there was a tiny piece of stone trapped between the disc and the backplate. Removed...sorted. Worth a look??
will have a look but don't think that is what it is.
2001 plate
Sounds like a wheel bearing, I replaced both mine because I had the ticking noise.
It was speed related too, I could really hear the noise if I drove close to a high kerb.
REALLY annoyed me for ages - didn't sound like a wheel bearing on any other car I owned, I even took the discs off to look for trapped stones ouich
Also, with the car jacked up and the wheel off you still couldn't tell it was a wheel bearing, everything felt good.
Instant improvement when I replaced them.
Discussion Starter · #10 ·
Tried dosn't seem to be any play and what you are saying matches it to a "T".
Thats all I need :grrrrr: not having much luck with this car but I'm getting to the bottom of all these faults slowly but surely ouichI just wish they'd give me a chance to at least drive the car with it all working :M5launch: b4 i spend a fortune fixing things.
Any ideas how much this will cost for bits etc???????:eek:oohhh:
Mine were replaced on the E+, but I think bearings are about 200€ (probably about the same in quid). I dont think its a crucial fault, as I ran mine for about 25000 km with the noise, but got it changed just before the insurance ran out. I personally would wait to see if it starts rumbleing, and change it then. Are you likely to change your own bearing or have a stealer do it?
Discussion Starter · #12 ·
got someone who will do it if i get the bits. :eek:oohhh:
1 - 12 of 12 Posts
