21 - 34 of 34 Posts
My understanding is that you should put 100km on the new o-rings before doing the test again.
So here my update guys..... installed the “repaired solenoids with new o-rings” that was provided to me by @Redleg9 and here were my results....
Car idled smooth unlike before it idled as if it had a CAM in it like a Vette. HERE my issue though I still have vano faults and car won’t idle long enough before it actually SHUTS OFF. Not sure why this is happening. My next step is to checking engine “timing” with the s85 timing tool, and if that is good then it has to be my vano units that are bad. Soooo I’m still without my car.
Good news solenoids read consistent across the board and repair seems to work that Troy did for me, but news still has vano codes and car won’t stay on longer than 2min before it drops idle and shuts off with vano codes...
Any suggestions or help would be appreciated.
It does, I don’t think I took a pic... but it was Fault codes for both banks. Intake and exhaust something for vanos. I will try and get pic
Can you elaborate on " repaired solenoids"
What exactly did Troy do to them?
To be honest I really don’t know what all were entailed as to what he did but it certainly worked and got my values up to OK status along with o-rings
Hmm... are you actually running the solenoid test or simply reading the stored values? The fact that all 4 read exactly the same is unusual. Simply resetting vanos adaptations sets all 4 back to 0.85. Sounds like you're simply seeing the stored values after adaptations were reset.
Yea I actually ran the test and remember these were repaired. I believe I shared my before and after results.... it wasn’t a rest though, we definitely ran the solenoids test plan
Before
After
Discussion Starter #30
For clarity's sake, I provided the O-rings, not the solenoids. I had a few extra Viton o-rings and squared M V10 Power away with a set.
That is correct. Thank you for that and it def seemed to help and make a difference in addition to me having Troy repair my solenoids. Thanks again
Ordered Viton o-ring set!
21 - 34 of 34 Posts
