1 - 4 of 4 Posts
Anyone use Dr. Vanos to repair instead of replace? If so, how much and how did it work out? Thanks.
I did order and install the new gaskets and o-rings. The existing o-rings were extremely brittle and I'm sure needed to be replaced, but I did end up ordering new solenoids and installing them on my problem bank. That fixed the issue.
Many have had luck with fixing the solenoids, and I did try that but I was not able to get them to function fully. Mine just would give me an issue from starting the car through about 2 minutes of driving, then the symptoms would disappear.
The $100 fix is a good place to start, in addition to the CPSs.
If you're wanting to replace the O rings + gasket, stick with OEM. It took them several years to degrade like they have.
1 - 4 of 4 Posts
