Has your car had a VANOS problem?
  • No
    Votes: 34 77.3%
  • Yes
    Votes: 10 22.7%
1 - 20 of 23 Posts
Since alot of M5s are beginning to get up there in mileage, I was curious as to how many cars actually have had a VANOS issue.
So please participate in the poll if you have an E60 M5 (unless the E39 had the same high pressure system, I don't know), and please indicate the following:
-Year of your M5
-Mileage of your M5
-Details of the VANOS problem if you had one (oil line, unit replacement, reduced power warnings, etc...)
I'll start:
2008 M5, 36K miles, no issues.
-Dave
2006
50,000
no serious issues
When I first bought it a 19,000 miles I had constant vanos noise. I drive it a lot more than the previous owner, and I'm guessing, a lot harder, and now, no vanos noise at all.
2001 m5 155k on it only have done selonoid seals as preventive maint however i am planning on pulling them out when i do valve cover gaskets and have dr vanos go thru them and remachine the bearings in the spline shafts. in the next couple of months the beast is going under the knife rod bearings , major serivce , vanos etc
2006 with 72k no issues. Had a 04 M3, vanos crapped out @ 60k, sheared bolts on the cams. common failure on these units
2008 w/ 39980-ish. no VANOS issues *knock on wood*
I had all the vanos valves (both banks and both exhaust and inlet) done at 55,000 miles plus they replaced the pump. Engine check light on if I moved the car on the drive but didn't go anywhere then after next proper journey (Fully hot/full start/drive cycle) light would go out until I just moved the car!? No other faults or symtoms evident. Dealer followed direction from Germany to fault finding and parts replacement which took 3 weeks due to ordering parts bit by bit then testing in between.
All under warranty.
Jay
2008 with 23k miles. I've probably had the car a
little more than a month. There has been an intermittent buzzing noise
coming from the left side of the engine. I had no CEL and the car
felt strong, so I saw no problem. Although, recently I took it into the dealer
and told them the noise might be related to the Vanos. The report says
that they verified the noise was the front vanos. There was a CEL that came up when they
hooked the car up to the autologic. They also felt a vibration in the vanos lines and
ran a bleed procedure 4 times. Retested for a CEL. Ran the procedure again. Cold started and
no more noise. This is word for word. Hopefully this stops the noise.
my 08 is giving me the same symptoms...in the shop now...getting bled today (hopefully not to *****:3:)...http://www.m5board.com/vbulletin/e6...ussion/171238-please-help-identify-sound.html
2006
37k
no problems
2006
47K miles
No problem yet but...........I sometimes go 2 or 3 weeks between driving it, and occasionally after a restart i get the dreaded VANOS noise. Only last 10 secs and then goes. Never get it when the engine starts from cold.
Just gonna drive it til it breaks!!!
2001 E39 M5 98,000 km no issues
2006 E63 M6 75,000 km SMG problem
2006 M5, 97000km (60000 miles), 3 out of 4 vanos magnets (what they called them) replaced a few weeks ago. No errors on dash, came up during regular maintenance.
1 - 20 of 23 Posts
