Vanos gear removal help!
1797 Views 13 Replies 4 Participants Last post by  P-Chi
I’m trying to rebuild my s85 engine and want to remove the vanos gears. But whenever I rotate the crank to tdc the intake cam is not facing straight up and the alignment tool is not flat in. I kind of took all the hexagon bolts out first. Am I doing something wrong? I didn’t put the special tool in first for the cam instead I took out all the hexagon bolts out. I read the tis wrong
Blue Motor vehicle Automotive tire Water Engineering
Photograph Automotive tire White Light Motor vehicle
Shoe Personal protective equipment Auto part Motor vehicle Metal
1 - 14 of 14 Posts
Because you missed up the timing by removing the hex bolts WITH washers. You probably also missed up the timing of the exhaust cam gear by NOT installing a M8X18 bolts at the back of the exhaust gears.
The 3 hex bolts WITH washers on each cam gear are what hold the spring tension inside the gears. When you removed the hex bolts with washers before the timing tool installation the spring tension released and missed up the timing.
Now your duty is to return to point zero then to follow procedure again.
First you need to remove the Vanos adjusters (you remove the hex bolts without washers).
Next is to position the camshafts back to timing position with a wrench and tighten the hex bolts with washers to 10nm. During the process the sleeve of the camshaft gear must moved forward. The intake sleeve may be easier to move by hand but the exhaust(if you lost the initial timing by not installing the M8X18 bolt) might be hard. One creative member managed to pull the sleeve of the camshaft for the exhaust be installing long bolt from forward to back through the sleeve to pull the sleeve forward then he tightened the hex bolts.
If you managed to get there then you install the timing tool on the camshafts and continue the removal procedure properly.
I suggest you read the procedure again for the adjuster removal, cam gear removal, timing check, and timing adjustment to understand the sequence and how the timing process work. pay attention the notes, important notices and warning of injury.
2006 bmw m5
Sorry I already removed the vanos gears and cam. Is the anyway I could adjust the tension back to where it was? I was so confused and someone told me to just take the gear off since I missed up already.
2006 bmw m5
after I put everything back together?
From last picture tighten the 3 hex screws on each cam gear to 10nm with the timing block installed as shown remove then remove the cam center bolt and lift the whole assembly(cam gears and timing block) altogether, then after the rebuild you put it back the same way.
Now since you removed the cam gears you need to put back the timing block between the gear sleeves to counteract the spring and extend the gear and tighten the hex screws with washers so the assembly is ready for installation.
You may not have difficulty to extend the intake cam gear but he exhaust gear is hard. There is a tool in TIS that you install it on the exhaust cam gear teeth to help align the teeth and counter act the spring to allow you to install the M8X18 bolt on the back of the exhaust gears, this bolt will stop the cam gear from retracting and allow you to put the timing block and tighten the hex screws to be ready for installation.
A member in the forum (other than me) after he installed the exhaust cam gear he installed a long bolt on the sleeve from Forward to Back in one of the sleeve holes to push the sleeve back and extend it then you can tighten the 2 remaining hex screws to hold the cam gear extended then he removed the bolt and installed the third screws. I think that what he did if I still remember, hope you get the idea and understand the timing position of the cam gears.
This is the tool picture:
Product Font Auto part Circle Machine
What I think is possible to realign the exhaust gear
Automotive tire Product Motor vehicle Font Automotive lighting
If you used long bolt to extend the exhaust cam gear to may not need to install the M8X18 bolt, just tighten the sleeve with the remaining 2 hex bolt with washers to hold it extended.
2006 bmw m5
Discussion Starter · #9 ·
Okay I give it a try whenever I put everything back together. I will go ahead and buy the cam gear locking tool. Thank you so much
· Premium Member
E60 M5 and building engines
Please keep posting on this issue. VERY much want to learn.
Basic concept is to avoid gear whine, so exhaust VANOS has spring loaded split gear to reduce NVH.
I avoided by following service manual, but still want to learn!
Also have back-set "service" screw many don't show and painted yellow to hold VANOS split gear in correct postion (load vs pre-load).....at time like this, wish I could get in contact with Troy....getting close....only to learn and share!
Attached and pics of zip-ties to hold VANOS gear timing....is this necessary? At least it keeps the spacing correct!
P-Chi
Thank you @P-Chi for posting this.
@Sollsam , this is the position you should reach just before you release the central camshafts bolts then you lift the assembly as in the 2nd picture, set it aside until reinstallation.
The timing position is held by the timing block and the 3 screws with washers, both gear are extended, sleeves all the way to the right, screws with washers tightened all the way to the lift. "Yellow" bolt is necessary to hold the exhaust cam gear tensioned.
This step is the most important and difficult to understand, the rest is simple, just to set the camshaft in timing position using the camshaft timing tool.
2006 bmw m5
Discussion Starter · #12 ·
P-Chi
Thanks for the help. I wish I read the manual first before removing the screws. Next time I will paint and zip ties the vanos gear
2006 bmw m5
Discussion Starter · #13 ·
Yes I understand now. Thanks for the good information. I haven’t decide yet if I’m going to rebuild it or just buy a second hand working engine.
· Premium Member
Well Sollsam.....Welcome to the club!
As many have posted, I am an full agreement. Get another engine.....but keep your current one!
Others may not agree, but I would tear that engine down to nut and bolts, inspect EVERYTHING, change rod AND crank bearings, VANOS H.P. line, AND.....confirm latest VANOS drive gears and ....
This is where I have to leave off. I want to tear into my VANOS H.P. pump to inspect....start a post!
Also understand there was a revision to the "oil squirters". Do not yet know if difference, but if revised, probably worth spending the extra few units or currency to bring the short-block to the latest and most reliable specs.
The heads tend to be flawless and as such, not worth much. I still pull mine apart and refurb, but I am also far to OCD and do not recommend anyone follow my advise.
NOW you have an engine, that properly warmed up and maintained should last well over 100k miles without having to worry. Only have oil checked for pre-mature wear (mostly from abuse in my humble opinion) and listen for sounds.
Best of luck for YOUR SUPER CAR, V10 in this new year!
PS: To anyone interested. The "yellow" cap screws were purschased from "Home Depot"....don't have spec in front of me but recall 18mm length. Was perfect according to service manual....if 18mm not actual, the actual was available and I just used a paint pen to make them yellow at the "cap"
P-Chi
1 - 14 of 14 Posts
