Yeah, I refitted the vanos regulator. Later, the vanos system test showed this result.
As a result of the measurement, Intake Bank 1
Maximum stop position: 154.4 CA
Minimum stop position: 154.2 CA
Adjustment time, opening too small: 130.0 ms
Adjustment time, opening too large: 550.0 ms
Minimum valve quality: 0.8
Valve current: 500.0 mA
As a result of the measurement, exhaust bank 1
Maximum stop position: 123.0 CA
Minimum stop position: 98.8 CA
Adjustment time, opening too small: 720.0ms
Adjustment time, opening too large: 460.0 ms
Minimum valve quality: 0.9
Valve current: 249.0 mA
As a result of the measurement, Intake Bank 2
Maximum stop position: 149.7 CA
Minimum stop position: 114.2 CA
Adjustment time, opening too small: 220.0 ms
Adjustment time, opening too large: 710.0 ms
Valve current: 323.0 mA
As a result of the measurement, exhaust bank 2
Maximum stop position: 129.8 CA
Minimum stop position: 107.2 CA
Adjustment time, opening too small : 240.0ms
Adjustment time, opening too large: 470.0 ms
Valve current: 251.0 mA
Still, the vanos test is abnormal.
Should the vanos gear unit be replaced?
Or should we replace the solenoid?
And now this fault code remains.
00275F DME: VANOS maximum-stop position, intake air, bank 1
