1 - 7 of 7 Posts
How are you guys invoking the Vanos Bleed and Test procedure in ISTA D when you don't encounter a vanos code in the DME ?
I'd like to read more about the procedure (offline) but it seems like the only way I could invoke the procedure is if the car has already encountered a vanos fault code during a vehicle test.
Maybe you can get to it by selecting the DME on the graphic screen of all the ECUs and then clicking the selection (I can't remember what it's called) for components down on the bottom just left of the middle. I believe that this takes you to a list of a number of the components including VANOS and throttle actuators.
I think that you can do something there but I don't know if it's tests or the bleed procedure.
Wow. Reading over that - it's really vague and wishful-thinking. But I'm too lazy tonight to boot ISTA up.
In Autologic it's really easy lol.
Here are the results I got from the Vanos Test on another persons car.
I ran the test twice back to back.
Test 1 - First 2 pics
Test 2 - Last 2 pics
Intake results listed only. (Exhaust results were close to being fine)
Notice on Test 2, bank 2. The max/min stops have gone way off on the 2nd test ! not to mention the spread time.
I should have continued with more back to back testing since inconsistent results were obtained.
If it were a pressure problem, I would have expected more than 1 of the stops to not be obtained. Going to have to verify the pressure on the car as well. Maybe HP line.
Could possibly be a solenoid that is real bad but then again I haven't seen anyone on this board have their max/min stops affected by solenoids.
This car isn't well.
I tested the same car again 2 days after initially testing it and got different results again !! Can't be a good sign.
1 - 7 of 7 Posts
