Ok.. Ive had this issue for a while.. I figured with New tires, balancing, and a 4 wheel alignment the issue would be solved..WRONG ! Every morning during my initial drive to work up to about 100kph the steering wheel vibrates (side to side) . I thought maybe it had something to do with the road but no.. Here is the funny part.. The shaking will go away after driving for a little while.. Same speed, same conditions, same road.. I've noticed that aggressive driving triggers it between these 2 conditions.. It will come and go at any given time.. I will be driving through the city smoothly one minute.. And after a few quick turns I'll be vibrating again.. I had the tire tech check the wheels and axles for any unusual "loose" movement or broken supports of some kind but everything checked out ok.. The bushings on the front stabilizer bar seemed ok also, I checked them myself while the car was on the lift.
This Love-Hate relationship with my car is starting to wear thin.. :3:
