1 - 3 of 3 Posts
Unused UFMotorsport S62 Intake Temp Sensor Relocation Kit (retails for $130 new)
$90/obo
from UFMotorsport's website: "The factory placement of the E39 M5’s air intake temperature sensor (inside the airflow meter) was a design oversight in this otherwise near-perfect car.
Since the airflow meters sit directly behind the radiator, the factory sensor sends inaccurately high temperature readings to the DME when the engine is hot. When the DME receives these false high readings, the engine’s performance is retarded to protect itself. In tests, the temperature inside the AFM is often over 45° F higher than the actual air temperature outside the car.
This kit relocates the sensor to the front of the car inside the airdam, where it will always send the true temperature reading to the engine’s DME. This simple modification will ensure consistent performance when the engine is at full operating temperature."
Hey Brad, I emailed you.
marekd174, could you PM me your email address? Sorry, I don't have enough posts to reply your PM.
1 - 3 of 3 Posts
