Unplugged wiring connector behind HVAC Panel
79 views 4 replies 4 participants last post by  technician117
#1 ·
Hey Folks - I am replacing my center console and found an unplugged wiring connector behind the HVAC panel. Any idea what this is for?
#2 ·
Did that not come from the rear of the hvac control unit? I just went through this to clean and lube the small fan.
#4 ·
Those are around the car. Some might be for things you don't have. Others have thought that some might be diagnostic plugs? Seems pretty simple though. Do you make many different versions of the wiring harness for each options choice or do you make limited harness configurations and simply not use the extra plug for the option that is not being installed?
#5 ·
It might be for one of the flap motors mounted to the side of the airbox. A small circular motor looking piece. You might need to take the carpeted (Or leather) side panel off to see better.
