81 - 84 of 84 Posts
I pressed the egg in until the narrow part faced right up to the threaded diff arm. It took a couple of iterations of removing the tool then lifting the diff into position to check though.
Discussion Starter #83
How far do you press in the unicorn egg? Should the end pieces (narrow part) line up with the end of the subframe? If I line up the outer part with the edge of the subframe on the diff side, the opposite side ends up recessed inside. View attachment 938849 View attachment 938850
The Egg in the last pic you posted is perfect. The rear edge of the Egg needs to be flush with the rear edge of the sleeve.
81 - 84 of 84 Posts
