1. There is a switch to control which side view mirror will be controlled by the directional keys for adjustment purposes. If you select the right hand side mirror, it will not go down. Also, read the manualplease help me with these annoying problems
1. whenever I shift into reverse gear, my right rearview mirror angles/faces downward... the left rearview mirror doesn't move. how do I stop the right rearview mirror from moving?
2. whenever I start the engine, the car automatically turns on AC... how do I turn off AC or heater completely?
p.s. I'm using a flash drive to listen to music but I don't know how to repeat the same song... how do I set it to repeat/shuffle songs on my flash drive?
2. I am not aware if any way to permanently stop the heat/ac. If you disable it once, I think it retains it for next time (only once). But other than that, I am not sure.
