1 - 3 of 3 Posts
this looks great for my 04' lexus GX 470. It has the MAkr Levinson stereo/NAV,
with DVD player. This is the first time I have seen this for Lexus. I would
recomend something like NAT-TV has for the BMW, they have it ready for
use while in motion, but it is more costly.:M5launch: :M5launch:
www.navwithtv.com
Wiring harness that plugs into existing wiring harness behind NAV unit. No cutting/splicing. No speed cut-off. Two composite video in's are provided (back up camera or other).
No TV tuner either (I don't care, will be using for DVD/PC video anyway, and you can buy TV tuner units with video out if you need it). You install a toggle switch to swap between viewing OBC/NAV and TV/VIDEO.
I'm in the process of installing, seems to work very well. For audio I chose to get the Soundgate "BMWDSP" and "AUX-3" units, which provides direct stereo input - also a toggle switch to activate - which the BMW stereo then thinks is CD track 99. Also installing but not yet tested.
Paul
1 - 3 of 3 Posts
