1 - 14 of 14 Posts
I tend to be a relaxed driver that prefers to cruise at high speed then burn rubber but when the time comes to make a 3 point turn without using reverse, I notice the car does not realize I want 100% performance till the second or third time slam the gas pedal.
Is there a tune that does nothing but keep it in car rental mode? I do not wand the A/F adjusted, I do not want to install a sprint booster to adjust the pedal response curve, I just want the car to act like I've been abusing it all day.
Confused.
T
Guest
I would say sprint booster is your only option.
Don't knock it until you try it. I have it in all my cars, even the Z06 and 745i. Will never go back.
Sent from AutoGuide.com App
It has the power but bogs down the first time I do it, second time I can smoke the tires at half throttle since there is no confusion or hesitation from the car
Sounds like the car needs some TLC.
How old are your spark plugs. Replace them if they are more than 40k kms old.
Change/clean your air filter. Clean your MAF sensors. Put a fuel system cleaner in the car with a full tank of fuel.
T
Guest
Set your m mode to p500s and dsc off, sport Edc.
If that doesn't immediately make a difference, then I am not sure what will aside from sprint booster.
When you say rental car mode, you mean beating on rental cars, right?
1 - 14 of 14 Posts
