1 - 20 of 22 Posts
Hello,
Recently I've been adding various accesories to my M6 and would like to tap off of other fuses in the trunk.
I have my little plastic card with symbols on it that indicate what each fuse is for but I don't understand what some of the symbols mean.
So far I have run a backup cam and a front camera off of Fuse #71. It does not appear to be intrusive to other functions of the car and the symbol sort of looks like it's for a rear motorized sunshade that goes on the inside of the rear windshield. Can anyone confirm?
Also - this Fuse/Circuit appears to have power only when the car is turned on.. supplies 12V (and doesn't drain the battery when the car is turned off). I need to locate another circuit/fuse identical to #71.
The fuses below are what I'm curious about - what are these used for? Can anyone offer ideas? or do they know for sure?
Trunk Fuses:
52
51
62,65
66
71 (Appears to be for motorized rear winshield sunshade)
87,88
52,66
60
I suppose I could call my BMW stealership and inquire with them - they should be able to answer I imagine.
Any input would be greatly appreciated :) :)
You might want to obtain a BMW ETM (electrical troubleshooting manual). Copies are available on eBay.
The wiring diagrams can be very helpful.
sorry to go off topic,
but do M6's have the automatic sunshade in the rear windshield?
mine doesnt have this, and here I thought I had every option?
The E63/64 probably has the same wiring harnass (fuse blocks, etc.) as the E60 5 series cars (which do have a sun shade option). At least that's my guess :tonquesmilie:
You are right, this was never a 6 series car option.
Thanks!
Ahhh yeah Dan and I have spoken a couple times via email. Thanks for the insight folks. I will keep poking at it to see what I figure out!
Majestic, this should get you what you're looking for. Use Firefox or Chrome browser (seems to work best) and search for fuse box or look under electrical in the tree. It will give you a wiring diagram of the entire fuse panel in the trunk. (there are also fuse panels behind the glove box and in the engine compartment, passenger side)
Good luck
Note: you're looking for a #15 wire, which is an 'Ign on' wire 12v when Ign is on
WDS BMW Wiring Diagram System - 6 E63 E64
Fuse layout with descriptions
My usual disclaimer:
1) Use this information at your own risk.
2) I do not guarantee the accuracy of this information.
The info I attached to the fuses is based on my interpretation on what was listed on the E63 Wiring Diagram Manual.
3) There are cases where numerous systems are attached to one fuse so I did my best to combine them all given the limited space available on the fuse nomenclature box.
4) Do not blame me or hold me accountable for any incorrect information or for any possible damage to your electrical system.
Do your own homework too and double check to ensure the information I have is correct.
5) Took me over 3 hours to research this info and put them all together. Time I could have spent with my wife and girlfriend instead.
A simple thank you will suffice if you are able to use this information for your project or to resolve a fuse issue.
Now that we got that out of the way, please see attached.
Discussion Starter #11
Woah!
Oh Wow Dan... this is exactly what I needed.. an interpretation of those goofy symbols. Thank you so much for taking the time to spell it out for me. You are truly an assett to the board!
Trunk Fuses:
62,65 (Trailor Module for M5 - definetely sounds like an option for tapping off of the car - I will check how it behaves
71 - (Rear motorized sunshade) - I've already tapped off of this with success.
52,66 - (Convertible relay sunroof - definetely sounds like an option for tapping off of the car - I will check how it behaves
Hopefully one of the above will suffice to power the FLIR Nightvision camera I'm trying to retrofit/install.
I will check the above fuses and report back on my findings.
Let the Wife (and girlfriend? haha) know I am hugely appreciative!
Hey bud, you are always welcome.
Yes, kindly share with us your projects and updates so that I and others can learn too.
The FLIR would be a really cool addition!
I cant afford a FLIR camera so I am installing a Pioneer forward looking camera on my beast this weekend.
As like in the past, I will share DIY procedures once I'm done.
Happy Veterans day to everyone, especially to those that served in the military like I did.
Thank you for your service to our country. Forever grateful.
Trunk Fuses:
Dan,
Have to give extra special credit for putting that fuse matrix together. Wow! If you charged for consulting services, you'd be wealthy(er).
Had to comment..
and Happy Vets Day as well.
Fellow Vet
Allan
:usa:
I find that very interested that it is not even an option, meanwhile it is an option on the M3 Coupe.
That is Odd to me
Thanks Allan.
And thanks again for your service to our country.
Dan,
Had to comment..
Fellow Vet
Allan
:usa:
Any updates on this? Besides #71, were the others useful?
1 - 20 of 22 Posts
