Follow this procedure: While driving anywhere between 20 and 90mph, put the car into neutral and then simultaneously hold both paddles back for ~3-5 seconds. This will reset your clutch position sensor, and your shifting will become smoother. A lot of people do it as routine maintenance every 2K miles or so, and after getting new wheels and tires and stuff.I have not heard of that, thank you. Is it through Idrive? Thanks again
i think the last person i heard say this just needed a new clutch and flywheel...i am guessing u have launched the car with the euro LC lol about 6 times of the will do itThanks but unfortunately it didnt work. It's not looking too good. If you get on the gas even a little it revs a lot before engaging and then I get the message again. Let you know what happens. Thanks for the help
Ur welcomenew front clutch, flywheel, TO bearing. Covered under the 1 time goodwill clause.
