1 - 7 of 7 Posts
i've driven my car for about 2 months now, put about 1500 miles so far. Car has 49,000 miles on the clock. Earlier while driving it i put it in M mode and got on it. After downshifting the "red cog" display came on saying Transmission malfunction, i got so scared. It went to neutral and into drive mode. After that i've been driving it and the light is not on anymore?? What should i do? Is is clutch slip? Im afraid to floor it now.....
Read the codes.. That should give some indication of what is going wrong.. The codes will be stored..
Where do i find the codes? i went to the Idrive and it says everything is fine. It only displayed that message for a few seconds.
Have to get it scanned.. Go to a performance shop or a mechanic shop, they will plug in the code reader in the OBD port and it will show them the codes.
Im going to have it scanned Monday. Its driving good and everything now, it only displayed that for a few seconds. Have you or anyone ever had that experience? There are no check engine lights, or nothing on the idrive. I'm just afraid to drive it hard now.
I had the exact same thing happen. Scared the bejeezus out of me. Then nothing for a month, and suddenly I started getting random failures from everything.
Turns out it was an early sign my alternator was dying. (Voltage regulator really). It *could* still be a transmission error, but have them check your battery and alternator voltages to ensure there is no spiking.
Thanks man. It freaked me out as well, i was in the middle of traffic too and it went straight to neutral but then drove fine. I will come back with more info once i get it checked out.
1 - 7 of 7 Posts
