1 - 12 of 12 Posts
Guy's, the beast is going to need some tranny work. Should I rebuild the 5spd,
get a new one, or swap to a 6spd. The car is a US spec 3.6 w/a 3.91 lsd diff.
It would be nice to have a 6 spd for the highway. :cheers:
It all depends on what work you need doing on your 5 speed. Is it the seals or is it a major hardware overhaul? I do know if you did swap to the 6 speed, you would also have to change your diff (Different ratios) and I think also the propshaft. This is not cheap option, upwards of £1500, then add in the grearbox work, miscellaneous parts and labour ??
I'd personally stick with the 5 speed and try to keep the car as original as possible?
Cheers
Brian
The transmission itself is in good shape but the syncros are about shot. The car has 150K miles on her. Seems like if it is a major deal to swap for a 6spd I'll just rebuild the 5 spd.
There's an extra 70kgs / 154lb weight in the 6 speed too. I'd stick with the 5 speed if you can.
cheers,
Phil.
I've found changing to a 6spd would be very involved and essentially not worth the money. I'm better off just rebuilding the 5spd. It will cost me 2K USD to do the job.
Just an idea, but you might be able to source a used gearbox for less? Maybe look at www.mobile.de or www.ebay.de. Could get a low miles one. Shipping would be a consideration though?
Regards
Brian
Be sure to keep us updated! I'm sure as many of our cars have more than 100K miles more and more of us may have to go down this road.
Thanks.. but is that with everything else that comes with it. As it was mentioned about changing other things also when doing this. 5- 6spd conversion. Would a quaife be a option?
Burton, Quaife is certainly an option for final drive / diff, i think they're 'only' £630, it has crossed my mind if they could service the gerty r280 box, I bet they could. Touch wood, my transmission components seem ok for now but I would definately get in touch with quaife if I had problems.
Leda suspension is another U.K. specialist worth checking out.
cheers,
Phil.
Yes, the 6 speed box weighs an extra 70 kg. It´s like carrying an extra human in the car at all times.
In fact, the fastest of the e34 M5s is the 1994 5 speed with 17 inch throwing stars and non-Nring package.
1. Brakes and susp are smaller and lighter
2. 17 inch wheels are lighter (therefore less rotational mass)
3. 70kg lighter due to 5 speed box.
1 - 12 of 12 Posts
