1 - 20 of 20 Posts
I am wondering if anybody has had this problem and can be of help.
I was at a track day last Sunday and my 3.6 just started to run extremely rough to the point I couldn't make it back to the pits area. Towing the M5 to the pits was not a good look :sad2:
It is over fuelling and running the injectors to full duty cycle. Have checked all sensors/MAF and it looks like the ECU has some issue. Can anybody shed some light on this for me?
Thanks,
Simon
Sorry to hear about your problem and I can't shed any light on it either.
It does raise an issue over track days in the car though. I have done one and it took a week to get the smile off my face.
It has to be said though, that with repairs costing an arm and a leg (my latest being a small leak on a self levelling valve costing £400 to sort out), there may be more economical ways of getting your track day fun. I admit that the reason for me not doing more track time is the mechanical worry of taking a 10 year old car and thrashing it at a time when it is approaching senility.
Or, I'd love to hear that there is no problem with rev limiting through the gears for a few hours per month and only need to concern myself with tyre replacement and keeping it away from the scenery.
A spare engine and gearbox would be a luxury and if Insurance companies were not so **** obstinate I would have had a full suite to pick from.
Hope the board can help out.
cherrsagai
Thanks,
Simon
Hi there QSZ
Dont start panicking yet. Its easy to think the worst with these old girls & Brian has raised some fair points.
Are the spark plugs & leads ok ? (Just checking) A track day can punish the plugs.
I would get the DME fault codes read as a starting point.
I would then guess that the fault will not lie with the engine management but with either the engine side water temp sender giving a false reading to the DME & putting the car into cold start strategy. This can be the sensor or the cooked wiring that becomes embrittled due to 10 yrs of Upheat.
Next up is the Oxygen sensor gone down which is far from unusual. Either way the fuelling will be shot with either option. Brittle wiring & cooked connectors has been a issue with my car in the last yr or so.
Things to fix start becoming more expensive after these two checks but assuming the DME is ok, this should point you in the right direction.
These cars can survive a track day, even the most punishing circuits like Nurburgring or Bathhurst as a comparison for the Southern Hemisphere can be fine as long as do a couple of laps & let the car cool down before going again.
There are far better choices for track cars & 1.7 odd metric tonnes does take its toll on the underpinings. Only a personal view mind you so not worth more than that.
Regards
Farrell
Simon.
I think I can help,had the same thing on my 3.6......
Had the fault codes read...no problems at all????
New air flow mass meter didn't cure it (still overfueling)
My mechanic is an Ex bmw tech and has spent alot of time trying to find the problem in his spare time and has come to the conclusion that the management system is not stock on my car and the chip (Eprom) has a fault, he's tested everthing else :eek: so....
today he gets the new chip and fits it after removing the alien bits and hopefully it should be back to business, I will let you know later.
I think you may have the same problem so I would go have the DME checked out first, (find a good company who remap chips to do this)
Oh and by the way the engine will run if the O2 sensor was disconnected totally (it wouldn't overfuel like it is doing)
Hope this helps, Andy S
Hi Guys,<O:p</O:p
thank you all for your quick replies. <O:p</O:p
<O:p</O:p
Brian, I have had it out on a track day before (Philip Is. Grand Prix Circut) and it was sensational, rounding up much more modern cars with ease. It did not have as much as a single problem, even brakes worked great with turbine trims on. Oil temp has to be checked in hot weather. My car is like new with only 140,000klms on it. You just have to remember your limits and all will be OK, you are not in a championship so remembering this you should be able to keep it off the walls.;) <O:p</O:p
Farrell, yes checked leads and spark all fine. DME is clear of faults. (DME can't tell you if it is faulty though). Checked all water temp sensors. O2 sensor won't cause the car to go to max. injector cycle so we don't think it is this. No fault code so it hasn’t failed and still is with in factory spec according to service OBD computer. Wasn't going to take it on this day but my Audi V8q track car met with an unfortunate workshop accident :-0<O:p</O:p
<O:p</O:p
Andy, I am in the business of tuning cars so have already replaced the stock data chip with a new one, no different unfortunately. Data had no faults or corruption but changed it anyway just to be sure. (still haven’t chipped it, too busy with other peoples cars) Their maybe a fault in one of the processors or resistors in the DME. I will try unplugging the o2 sen. just to see what happens.<O:p</O:p
Thanks again Guys.<O:p</O:p
Simon
QSZ<O:p</O:p
<O:p</O:p
I would echo farrell on the brittle wiring part. I had an A2 Jetta GLI that would regularly display the symptons you are describing. All the diagnostics pointed to the ECU. Each time it was a ground wire that had become brittle and broken. Hope this helps.
Yes the the car will run with the with a disconnected Lambda sensor but it will not fuel correctly. The system is a closed loop 3 way control using Lambda to define the A/F ratio. When you disconnect the Lambda probe the system goes open loop with consequent variances to fueling as the ECU tries to compensate for mixture variances which will always increase HC levels whilst it attempts to pull the catalyst op temp up above 250 degrees C (400 to 800 C is optimum )
On other cars with close coupled Catalysts, this over fuelling would usually destroy the washcoat treatment on the monolith. Lucky for us that the cats are under floor..
It is entirely possible with an intermittant operation of the Lambda probe to get over fuelling but if you also have incorrect cold water temp readings when the cooling system is already at optimum working temps returned to the DME, this will also incur a cold start duty cycle as fuel will be increased to support a cold start the DME believes is required.
This is all moot however if the fuel injectors are running @ full duty with no return to dwell.
I wonder QSZ s CAR is fitted with cruise control..!
Its very hard for any of us to get a feel for the fault when diagnosing thousands of miles away.
I hope QSZ resolves his issues regardless
Regards Farrell
Discussion Starter · #8 ·
I will check all the ECU earths and keep plugging away with it. When it happend the car was going strong. Just had a little dip in power when acc., then brake for corner and then went to power out and nothing but coughing and spluttering.
I don't have a cruse cont.
Cheers
Simon
Discussion Starter · #10 · (Edited)
Hi Andy,<O:p</O:p
I will keep at it here as well. I was supposed to get a loaner ECU from somebody today, but he didn't call.<O:p</O:p
Lets hope one of us can sort this quickly and help the other. I am missing my rough idle and M acceleration. The AmD cooper S just doesn’t cut it even though it has 210bhp.:viking:
<O:p</O:p
Have a good Sunday,<O:p</O:p
<O:p</O:p
Simon
Discussion Starter · #13 ·
Hi Andy,
any luck with your car? I found thses guys who say that can repair my ECU. As they have done one before.
Avilec Ltd T/A Car Electronic Services,
Unit 307,
Solent Business Centre,
Millbrook Road West,
Southampton, SO15 0HW
UNITED KINGDOM
Tel: 023 80777748
Cheers,
Simon
Simon,
yes and no......
My mech fitted a reconditioned ecu and now the car will run but only on idle and is still rich on the fuel side of things..:crying:
Today a guy has been to the car who repairs car ECU's for a living but I didn't get home from work in time to call him to see if he got it sorted/found the problem...:rolleyes:
This is one real hot S of a B hmmm
When I get to the bottom of this problem and post the findings I want a life honoury membership on this forum :hihi:
Andy S
Discussion Starter · #15 ·
Hi Andy,
How did you get on with the M5, is it running again?
Mine now has no spark and no fueling after the mechanics took me for $800. The ECU works fine too as I ran it in another car.
I am going to work on it this weekend.
Missing it allot, it looks all sad in the garage corner :crying2:
Simon
Discussion Starter · #16 · (Edited)
Hi Guys,<O:p</O:p
well I have found the problem. After the expense of taking it to people who should have known better (couldn't get into my BM specialist as they were too busy for the week), i got a mechanic friend of mine and we went to see my BMW specialist, whom normally services my car, to borrow a fan removal tool. <O:p</O:p
He suggested I check the main crank pulley as this can slip on the bonding if the car is old. Main crank pulley bolt was just about to fall out, 3 turns and I had it in my hand!!! The keyway that holds the crank pulley in position has snapped and so the pulley had moved about 1 cm further round, no wonder it wouldn’t run.<O:p</O:p
<O:p</O:p
I am going to get parts for it next week and hopefully we can dig what’s left of the keyway out of the crank, or it is crank out of motor time.:mad:
I will let you know how I get on.
Moral of the story, go to somebody who knows BMW'S even if you have to wait the week to get in !!:sad3:
Simon<O:p</O:p
QSZ said:
Hi Guys,<O:p</O:p
<O:p</O:p
Simon<O:p</O:p
Simon....
Just read your E mail tonight and called my Mechanic I have the same problem the pully was slipping will be repaired tomorrow ...Time to burn some rubber :D :M5launch:
Simon...Guys
Just got back from collecting the M5 and its a real winner thanx for all the help and suggestions along this bumpy road and I hope that the information given helps some poor soul to find this fault alot faster than it took me and simon.
Cheers Andy S..:cheers: :thumbsup: :M5launch:
1 - 20 of 20 Posts
