1 - 11 of 11 Posts
I'm installing a Kelleners sport exhaust on Monday.
Do I need to weld or is it enough to use the clamps that came with the
set ?
I have read different threads here but not sure what to do.
Super Moderator
i have my supersprints clamped on, not welded. No ses lights or other issues.
mike
clamp...if there is a leak, then weld
im getting my kelleners put on tommorow and im sure im just gonna get it clamped on
Mark
I installed my Kelleners and SS x-pipe myself with some friends about three weeks ago and we just used the supplied clamps, and I dont have any issues with leaking, I believe if you weld it, that you may have to drop the whole exhaust just to properly weld it, and doing so may make it harder to remove in the future for other Jobs like clutch rplacement and what not, the clamps should be fine, Josh
Clamping it is always better IMO. Not only is it sufficient in preventing leaks, but it also allows you to remove the muffler quick and easy compared to welding,
Discussion Starter · #10 ·
Can I cut the exhaust while it's on the car, or do I need to take it down and
do the cutting ?
Kjell
I have to disagree
Sorry to have to disagree with the majority here but welding will always be the better way to go. If you think you can just unclamp an exhaust and change it out, guess again. If the clamps are tightened properly in the first place to prevent leaks they are going to crip the pipes, making them very difficult to get off easily.
Cutting the pipes is much easier and welding will provide a longer term solution to leaks than clamps. I am sure there are those who have had good experience with clamps, but if you ask any good muffler shop, they will always advise the welding method.
I have had 4 different exhausts on my car and welding and cutting was never an issue for a professional installer.
Mark
1 - 11 of 11 Posts
