1 - 9 of 9 Posts
So looking to purchase some tires for my 20 inch wheels.
20X9 fronts
20X11 rears
I was looking at 245-35-20 fronts
295-30-20 rears
I'm looking for a slight stretch...
Problem is that not that many tire brands have the rear set up I'm looking for.
Toyo does however. Anyone have any experience running this set up on 20's?
BTW, I have KW 3's on the car now so also concerned with something not too tall. However I checked the diameter of the setup I address above and it's the closest I can find to the stock 19 inch set up....
Any help would be great?
I would do 255/35/20 in the front but 245 will do if you want the "stretched" look. As for the rears you can choose from Generals, Goodyear, Continental, Pirelli, and Toyo.
I'm running Forgestar 20x9.5 and 20x10.5 with 255/35/20 and 285/30/20 Hankooks. I also have KW V3's and it's slammed. I don't rub with the setup I have now.
Do you have a picture of your car? How's your stance with Forgestar?
Joe,
I am looking for the "stretch" look, what I'm curious is if a 295 would be fine in the back witht he KW's "slammed?"...
Do you have a stretch with the 285 in the rear with the 10.5 width.
Eric
I have a stretch look with Michelin ps2 285/30 on 10.5 wheel.
Exactly, I see that a 285 will "stretch" on a 10.5. Does anyone know if a 295 will still "stretch" on a 11 inch wide rear wheel??? I have not came across someone with this set up and I'm not too sure as why. Also will I have any rubbing issues with a 295 on a 20X11?
1 - 9 of 9 Posts
