see earlier thread on pressures
the concencus before seemed to be that you sacrifice grip and comfort with higher pressures. If you want more bite in the tires, try lower pressure. i agree this will generate more heat in the tires, but if you operate these tires in their spec range, they should have zero problem. 34/38 was discussed
