1 - 1 of 1 Posts
It's easy once you ignore the directions.
If you have a license plate frame, you may have to remove the plate first.
First open the trunk to get a good working angle. Use a medium blade screw driver, put it at the left edge of the plastic part (not in the slot), and push it right. It should easily push right 1/8 inch (the manual says push left). Then use the screw driver to carefully pop the left edge away from the metal area. Once the left side is loose, it is pretty easy to work the assembly out of the hole.
PS, it is a very odd bulb but I did find it at a Napa auto parts store.
1 - 1 of 1 Posts
