1 - 20 of 26 Posts
I've searched a bit and it seems there are partial parts lists all over, even in the install and how to threads. Has anyone ever purchased the complete set of guides and associated parts to do this job, or is it always a 'Well, I'll buy a few pieces, then when I'm part ways in, I'll buy some more' sort of a job?
Any help is appreciated. I'm debating on doing this to my 130K engine. Not sure it's needed, but probably safe insurance.
Thanks!
I'm interested as well. My local shop quoted the job out at $819 in parts and $4800 in labor.
Ouch. That's a lot of Labor. I'd probably do this myself. I just don't want to drive 1.5 hours to the car and be missing a part and have to leave the engine torn apart.....more than it already is, haha.
There really isn't much reason to replace the timing chain guides proactively. I did, but that is because I was doing the Valve Cover & Upper Timing Chain Cover Gaskets anyway. The most reasonable approach is to check the condition periodically (check for pieces) and if they're not broken then there is no point. Once you see they start breaking, then you should replace them ASAP. There will be plenty of warning signs once they start cracking and your engine won't be in any sudden danger such as it would if you had a cooling system failure for example.
There might be pieces of plastic/aluminum in the oil sump and oil filter. Rattling sound usually indicates that the chains are already shaving aluminum of the chain guides (plastic rail surface already gone) or inner surfaces of the lower/upper timing covers.
Are all the VANOS O-rings still from the factory without any refurb done? Then at that mileage it might be beficial to perform full VANOS refurb by replacing all the O-rings and diaphragm springs because you will have to take VANOS units off anyway. The length of the part list somewhat depends on that. S62-gurus in this forum usually recommend to replace the duplex main chain and cam chains "while you are in there" to play safe with relatively low additional cost.
My indy will do mine very soon. I followed the list published by VantaaM5 with few additions from VANOS-related forum threads:
Timing Chain Guide Replacement Including Full VANOS Refurb
11141275466 x 1 (Shaft seal - Lower Timing Case)
11140001186 x 2 (Upper Timing Cover Gasket Sets)
11140001187 x 1 (Gasket Seal - Lower Timing case)
11431707164 x 2 (O-ring)
11131407532 x 1 (Steel Gasket - Oil Pan Bottom)
07119963151 x 1 (Gasket Ring - Oil Pan Bottom)
11311407052 x 1 (Timing Chain - Timing - Timing Chain Lower P)
11311406366 x 1 (Deflection Rail - Timing - Timing Chain Lower P)
11311406280 x 1 (Guide Rail - Timing - Timing Chain Lower P)
11311407337 x 1 (Chain Tensioner Rail - Timing - Timing Chain Lower P)
11421713597 x 1 (O-ring for 11311407337)
11311406261 x 1 (Hydraulic Chain Tensioner - Timing - Timing Chain Lower P)
07119963355 x 1 (Gasket Ring - Timing - Timing Chain Lower P)
11311406167 x 2 (Chain - Timing Gear / Timimg Chain Top)
11311406165 x 1 (Chain Tensioner - Timing Gear / Timimg Chain Top - Cyl 1-4)
11311406166 x 1 (Chain Tensioner - Timing Gear / Timimg Chain Top - Cyl 5-8)
11367830147 x 1 (Hose Elbow)
11151407344 x 1 (Return Hose - Crankcase-Ventilation/oil separator)
11151406902 x 1 (Return Hose - Crankcase-Ventilation/oil separator)
07129952107 x 2 (Hose Clamp - Crankcase-Ventilation/oil separator)
11151406900 x 1 (Return Hose - Crankcase-Ventilation/oil separator)
11120001269 x 1 (Profile Gasket Cyl 1-4 - Cylinder Head Cover)
11120001278 x 1 (Profile Gasket Cyl 5-8 - Cylinder Head Cover)
7589062376 x 1 (BMW Drei Bond 1209 Sealant)
11121721879 x 6 (Rubber Seal - Cylinder Head Cover)
11121437395 x 20 (Rubber Seal - Cylinder Head Cover)
11511406765 x 1 (Steel Gasket - Water Pump)
11231402618 x 4 (Torx Bolt - Belt Drive-Vibration Damper)
11531710055 x 1 (O-ring for Water Pump)
11531407002 x 4 (O-ring - Lubrication System Engine Oil Cooling)
11531406249 x 6 (O-ring - Cooling System)
07119963072 x 4 (Copper Gasket Ring - VANOS)
07119919625 x 24 (Filister Head Screws - Timing Gear / Timimg Chain Top)
07119913589 x 24 (10.9-Rated Hex Bolts - Timing Gear Timing Chain Top)
11427510717 x 1 (Oil Filter)
OIL + ENGINE COOLANT + Few spare o-rings for possible thermostat & WP installation problems
Vanos Refurb/Rebuid:
11367830828 x 8 (Solenoid O-Rings)
11367830829 x 8 (Solenoid O-Rings)
11361406838 x 2 (Cover gasket)
11367833218 x 4 (Diaphragm Spring Sets)
11361406944 x 2 (Washer)
07119934749 x 2 (Lock Ring)
11311317318 x 4 (O-ring)
11361406377 x 2 (O-ring)
11311317732 x 2 (O-ring)
11361406868 x 2 (O-ring)
11411306082 x 2 (O-ring - VANOS)
11361401971 x 1 (Filter - 100bar oil regulator valve)
11311318659 x 1 (O-ring - 100bar oil regulator valve)
11361403325 x 1 (O-ring - 100bar oil regulator valve)
Optional:
11511406933 x 1 (Water Pump Pulley - Old one easily breaks during tear down)
11511407806 x 1 (LASO Water Pump - this package might include the steel gasket) /
11511407113 x 1 (Genuine BMW Water Pump - steel gasket must be bought separately)
11537835558 x 1 (Thermostat)
11531312287 x 1 (Thermostat Housing Gasket)
Spark Plugs x 8 (NGK BKR6EQUP Laser Platinum)
I know this is extensive list and contains optional parts but I hope it helps. At least the stuff behind timing covers is something that should be done only "once and right" :)
Very extensive.....but very cool.
I've done VANOS refurb as one side was leaking. I'm not sure if I pinched something as they appear to be weeping a bit again, although it could be a Valve cover. I might just go nuts and do it all again.
If I blow something apart with my forced induction plans, I'd rather it not be maintenance related.
Thanks for the replies!!
Shop around for this part.
It is on backorder at many places, supposedly until mid-september.
BMW has said that in Germany spare part warehouses will receive new stock on 8th of September. Here in Europe that damn rail has been out of stock since early June. Just frusfrating because the whole job has to wait that one critical piece :mad:
Optional:
Having just done all of it, that's a solid list. I'd suggest a couple changes:
-If your coolant system if new, nix it
-if your idlers/tensioners/pulleys are over 100,000, add them to the list
-Beisan VANOS products if you're already in there and over 100,000 miles
Discussion Starter #16
Wow....yeah, looks like I'll be ordering these parts this week. Mine is at 130K-ish miles right now.
Stop it! You guys are scaring me....:eek7:
Reactions: Boris///M
Discussion Starter #18
Would like to bump this. I was able to order everything but the Lower Tensioner 11311407337
Seems like it is still back ordered....they are saying December now. Anyone know of a secret stash somewhere?
I searched high and low and found nothing. BMW UK told me they searched the UK and Europe and also found nothing although eaM5 on here found 2 in Helsinki and kindly bought one for me and sent it over without me asking about it as he knew i'd been searching without success so a massive shout to him for his generosity.
Unfortunately it doesn't really help you out but i'd say ask the dealers to check the US and if they can perhaps Asia for dealer stock, otherwise you'll be waiting until at least December
Is this part M5 specific or can we cross shop with the 540? I might need it this winter too.
1 - 20 of 26 Posts
