21 - 40 of 41 Posts
I can buy the recommended(by you) "i910-II by icarsoft" but when i buy it as i am not a mechanic and not even close, so how do i use it to get the error code?
I am am certainly going to buy that thing if i can actually use it.
Thanks man, appreciate it.
all you have to do is plug the device to the obdII port. the port is located on the drivers side just above hood release there is a small door labeled obdII .......flip open and plug adapter in.
no one can help you on the forum without the codes ....... plus no one will help you with some of these basics ..... you will have to take the time to search and read info on forum .........
the search button is your best friend ....... there are step by step postings already written that show you a do it yourself (diy) way to fix the problem ..... reading not your thing? search youtube there are plenty of videos showing throttle body actuator installation.
also, buy icarly sounds like you will have better luck with it much easier to use than i940-II ... you can find it on amazon ..... adapter is 40.00 and the software is about 50.00 make sure you buy a genuine adapter so you can get support and buy the one for your phone ie apple or android software can be downloaded ........
you will have an easier time reading seeing and clearing codes with carly for bmw
https://www.amazon.com/s/ref=nb_sb_ss_c_0_10?url=search-alias=aps&field-keywords=carly+for+bmw&sprefix=carly+for+,aps,137
Just read your reply. I understand very well not being a mechanic and its frustrations. The guy I recommended has been consistently correct and more than reasonable with me on prices. His shop is well regarded and always busy. He has saved me countless $$$ and always gone above and beyond. Go get your car scanned. I doubt he would charge you for hooking it up and reading the codes. He will give you a fair assessment and you can go from there. I totally understand your concerns having faced this 2 years ago.
Shop is M-Chanics in Valley Stream, NY. Owner/mechanic (M5 Deamon) is George. Call him at 516-590-0660. I've worked with him for years and highly recommend him.
How many miles on your car? It was an '08 yes? Ever had the rod bearings done?
Discussion Starter #23
its 06 82k miles
and just bought the car so dont know he history of repairs
and haven't done any repair other than this one am trying to repair
if you have an iphone ....... yes this is the adapter ..... you will also need to download software ..... go to download store search for carly for bmw ..... buy software and then you are done.
this will allow you to pull all fault codes and email them to yourself which you can then post for help on forum plus you can clear faults, code your car for extra functions, reset service intervals and many more functions well worth the investment.
based on mileage and what you describe it sounds like actuator .... you should really replace both with new ones ...... these fail and mine lasted until about 91k which is pretty good ....... if you need them now ecs tuning can get them for 725 if you can wait buy from fast attack they are 625 plus you will be supporting a forum member that contributes a lot to the community.
order reader pull codes and let forum know ...... you will get much more help if you can give those
Discussion Starter #26 (Edited)
Yes i use iphone, so will buy it now
The mechanic told me buying from bmw/dealer comes with 3 years warranty..is that true?
Does fast attack come with warranty?
ask JColley about that through his site - I'm pretty sure they (ECS and FastAttack) are for one year - Since JColley is all over this site offering assistance I would discuss this with him ......
ECS sell GEN BMW Stamped part for 980 or so ..... you really need to change both especially with the mileage - save the one that good for a just in case moment thats what I did.
Plus while they were in there I had all filters cleaned and/or changed, new plugs, coil packs checked and new clips installed if any were deteriorated, both throttle body actuators, and both idle control actuators since my mechanic was going to be in there - they are prone to fail as well - since mine is a daily its cheaper to be very proactive and preventative for these known issues.
Hope this helps .... BTW - you can buy both VDO actuators and typical labor for install for less than the cost of 2 GEN BMW branded .... if you use GEN plan on a 2,600.00 job including labor or use VDO ECS - around 2,000 or wait for Fast Attack to get more and spend 1,800.00 - choice is yours
Oh and BTW those prices reflect 550.00 in labor which is what i was quoted for install
Discussion Starter #28
What do you mean here? Is there a way to know which is bad and which is not? maybe i can just change one at a time.
You mentioned you change all those as well, were those expensive parts as well?
You mentioned you change all those as well, were those expensive parts as well?[/QUOTE]
no, filters for cabin around 30 to 35 ...... ecs sells the ignition coil clip for about 4.00 each plugs are 11 each ........
idle control actuator ..... yes expensive 578 each and there are two
total bill for all filters, parts, oil, oil additives and labor around 3500
peace of mind ...... priceless .... again idle control had not failed but changed both anyway just in case i figured since we were in there might as well. its just one less thing to worry about.
Discussion Starter #31
peace of mind ...... priceless .... again idle control had not failed but changed both anyway just in case i figured since we were in there might as well. its just one less thing to worry about.[/QUOTE]
The carly thing arrives tomorrow so will check the code and post here
cant wait to repair this thing, enough with the reduced power thing seriously
cant wait to repair this thing, enough with the reduced power thing seriously[/QUOTE]
trust me i understand ..... be sure to download software there is a charge from download store. good luck you will be back on the road with her running strong soon enough
if you havent gone here yet check out what it will do
Carly for BMW - The Most Powerful BMW App Solution
hi bring me the car I will scan it and tell you what is wrong as many have recommend me to you there is a reason I have multiple e60 m5 and e39 and f10 m5''s at my shop at once feel free to contact me 516 599 0660 is the shop number if I do not answer leave a message and I will return your call. looking forward to potentially helping you.
Discussion Starter #34
Ok will contact you soon
Discussion Starter #36 (Edited)
did you get this resolved?
I have finally diagnosed the car with carly for BMW hardware and iphone app
Below are the report; so please advise
Code:
BASE: E60 E61 M
BUILD-YEAR: 2006
MODEL: M5   alle/all  (77)
[B]FAULTS: 13[/B]
ECUs: 32
BATTERY: 11.3V
DEPTH: Normal communication
SPEED: normal
CONNECT: Fast Connection
VERSION: 9.3.2
DEVICE: >iPhone< >iPhone OS<
WIFI: >Carly Adapter v00<
ELM: >ELM327 v1.4 v16<
COM+: >UNKNOWN<
0. Motor Control:
[B]Engine / Motor:
- Fault: Failure detection cyl.12
- Code: 002749
- Fault: Predriver check throttle valve actuator
- Code: 002B21
- Fault: check at lower top
- Code: 002B57
- Fault: Throttle initialization Bank 2
- Code: 002B2D
- Code: 002B22
- Fault: Injection control valve
- Code: 0027B0
- Fault: Failure detection cyl.8
- Code: 00274B[/B]
1. ABS / DSC / Brake:
Active Roll Stabilization / Rollstabilisierung:
- ECU not present/no answer
[B]Dynamische Stabilitaets Kontrolle / DSC:
- Fault: Engine torque is not adjustable CAN
- Code: 005E19[/B]
2. Airbag:
Advanced Crash and Safety Management (ACSM):
- ECU OK, no fault code
Satellite front left door / Tuer vorne links:
Satellite front right door / Tuer vorne rechts:
Satellite B-pillar left / B-Saeule links:
Satellite B-pillar right / B-Saeule rechts:
Satellite center / Mitte:
Airbag B-pillar left/ B-Saeule links:
Airbag B-pillar right/ B-Saeule rechts:
3. Transmission Control:
[B]Transmission / Getriebe GS 19:
- Fault: :Evaluation of lateral acceleration
- Code: 00520B[/B]
Transmission / Getriebesteuerung:
Gear switch / Gangschalter:
4. Instrumentation:
Instrument cluster / Kombiinstrument:
Central info display / Zentrales Display:
Head-Up Display:
5. Light/Rain Control:
Light / Licht:
Rain/light sensor / Regen-Lichtsensor RLS:
Light / Licht:
High-beam / Fernlichtassistent:
6. Heating / AC:
Air conditioning / Klimaanlage:
Additional heater / Zusatzheizung:
7. Immobilizer System:
CAS:
8. Park distance control / PDC:
Park Distance Control / PDC:
9. Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung:
10. Sunroof / Roof:
Sunroof / Schiebedach:
11. Audio / Navigation / Communication:
Multimedia-Changer / Wechsler:
Speech recognition / Spracherkennungs-system:
[B]Phone / Telefon:
- Fault: Error in the Bluetooth BT interface
- Code: 00A379[/B]
[B]Hifi Amplifier / Verstaerker:
- Fault: Long and / or frequent Unlocks
- Code: 00D6D1[/B]
Tuner Antenna / Antenne:
Hybrid Radio USA:
Digital Satellite-Tuner USA:
Headphones / Kopfhoerer Schnittstelle:
Navigation:
CD-Changer / Wechsler:
Audio-System:
Video:
DAB:
12. Seats:
Backrest width  / Lehnenbreiteverstellung:
Seats / Sitze:
Seats / Sitze:
13. Systems:
Gateway:
[B]Steering column switch / Lenkstockschalter:
- Fault: LRE monitoring of voltage above the upper limit
- Code: 00951B[/B]
Fuel pump / Kraftstoffpumpe:
Tire pressure control / Reifendruck Kontrolle:
Passive Go System:
Power Module:
Night Vision:
Flexible Bus-Interface / Schnittstelle:
[B]Car Communication Computer CCC:
- Fault: Message failure
- Code: 00E18F[/B]
MASK:
Center-Konsole:
Night Vision Camera:
Car Communication:
14. Anti-theft alarm system:
Interior protection / Innenraumschutz:
Theft alarm / Diebstahl Warnanlage:
15. Chassis:
Air suspension / Luftfederung:
Electronic damper / Elektronische Daempfer:
Central Control / Zentrale Bedieneinheit:
16. Body:
Automatisches Front Steering:
Trailer / Anhaenger:
Car Body Module:
Tailgate / Hecktuer:
17. Other:
Discussion Starter #37 (Edited)
I have posted the report from the carly for BMW app above
Will call you tomorrow (saturday)
The DSC fault is likely because of the throttle actuator faults. Both of your actuators are failing the pre-start test. That's 2B21 and 2B22 (closing spring test - i.e. it's sluggish when the throttles are closing instead of snapping shut. This is likely the circuit board. It can also mean Combustion misfires, several cylinders).
2B57 is your Air Mass sensor (Is it maybe unplugged?) and 2B2D is related to bank 2 initialization. It's tough to say what this means. Nothing good, though.
If you need 2 new TA circuit boards = 2 new TAs since they're not sold separately. Take out the 2 TAs. Push on the little ball lever and see if it returns to start quickly or drifts back. If the latter, your circuit board is toast. Even if the former - your circuit board could still be toast as I found out when my TA on bank 2 failed only 1 of the tests of about 15 or so.
Looks like you might need a new coil for cylinder 8 (maybe there is an oil leak :dunno: )
Discussion Starter #40
So far i haven't noticed any oil leak
Thanks a lot for your analysis, appreciate it
21 - 40 of 41 Posts
