Sorry to hear this.
Lousy way to spend your birthday. Good luck...
:sad2:
--Edit--
YOU SHOULD BE ABLE TO PUT YOUR CAR IN NUETRAL WITHOUT STARTING:
I wanted to verify with my car first... Here is what should work (key in ign. if you do not have comfort access, I do).
DO NOT PUT YOUR FOOT ON THE BRAKE so the car will not start, then:
Press the start button (radio readiness mode or acc. mode, if you rather), then:
Press the start button again (engine start/on mode, but car will not start without your foot on the brake), (car will warn you to put your foot on the brake or something), then:
Wait a second or two, then:
Put your foot on the brake and move it from Nuetral to drive and then back to Nuetral (maybe twice it it doesn't work first time).
Mine will go into Nuetral without having to start the car. Yours should too.
This should at least prevent you from having to let them drag your car onto the truck. Hope it works and you read this in time...
Good luck.
:sad2:
--Edit--
Good luck.
