I started a thread in Oct '09, entitled the same, as one morning, after a good run in the countryside the day before, she just refused to start. No battery trouble, but no spark at all. Back then it was the fuel pump, so I'm guessing it isn't that again after just 1.5 years....?
So if it's not the pump, I think I'm only left with the relay that could cause such a catastrophic failure? She was on top form on Monday when I took the day off work and went for a serious session in the sunny spring countryside. I parked her up that evening, and this morning, nothing. There was the faintest whiff of a catch as I first turned the key, then nothing at all. The symptoms are identical to when the fuel pump failed.
I had to rush to work, so I haven't plugged in the INPA yet, but I thought I'd post to get alternative possibilities from the wealth of knowledge out there. Does the relay throw a code, or does anyone know what vltage should be at its output?
Cheers for any help and advice guys!
Barney.
Barney.
