I wouldnt have added it to mine if i didnt think that taking into consideration all variables, it was worth it.
I got a Hartge M5 H 50 with 3:45 diff and love it. I my opinion this is how the M5 should have been from the factory. The resonse is incredible in every gear, however, down shifting from 6th to 4th going 140 km/h is a rush! The car responds immediately and goes like bullet! But of course everything is relative. It's not as fast as my F 40, but then again my F 40 doesn't have room for my kids and luggage! Tom:viking:Black M5 said:There was all this debate whether the 3.45 diff really gives you any advantage or not and i remember someone saying it cant given the same redline.. so my question is what happens if your redline is really 8000 rpm and have alot more power than stock.. ie my car! To be honest, im was never impressed with the 3.45 diff as it make you shifter faster without a clear advantage..
however im giving it second thoughts with my car and its new redline and high lift cams... the situation of car was that i never got to really see it past 7000 with boost only at 12 psi with another 6 psi and 1000 rpm in hand due to the SC belt slipping... make no mistake the car is a bullet and i have seen 320 km/h with the 4 on board with ease (with short shifting at 7000 in all gears) but i was thinking if the 3.45 diff will actually make it pull harder in the mid and top end range... i know im kind of jumping the gun and am eager to see how my car will perform with max boost at max rpm :M5rev:
so with the given info, do you think the 3.45 diff will be a good mod with an advatage all across is there is a pay off area where the 3.15 take the lead ? dont forget that my hp and torque are upward slopes all the way to redline mmmmmm
Rob Says it like it is!! I Second that Emotion!SC'dKellenersM5 said:I wouldnt have added it to mine if i didnt think that taking into consideration all variables, it was worth it.
Abdulla, honest man, who do you expect to take you with an M5? Have you lost your mind? Really...im being serious. You and Josh now own the most powerful ones on the planet..who else? No one. So no one with a M5 is going to take you even if they have a 3.15 or a 3.65Black M5 said:Kelleners, im only considering it cuz i want the car to pull harder on the top speed especially after 280 km/h
ranumm5,
My car has more than 700bhp and is surely faster than my Diablo SE30.. but i dont want to add the shorter diff and loose any top speed or have to trade off at any given point.... yet it pulls good past 300 and easily eventhough im short shifting which is below my max hp and torque... still 1000 rpm to go and 6 psi on a set up that just pulls harder the faster the engine spins...
yet again, i think (not sure) the rpm was at 6900 when i saw 320 so i still have plenty of unneeded rpm in top gear
can anyone tell me if the stock diff will pull ahead in higher speeds ? ??????
remember the interest is in mid-range and top end and not accelerationgra8fuldd ed said:I wouldn't have added it to my M5 If I didn't think it would help my "Off the Line" performance. It absolutely DOES Help my Off the Line Performance ! !
ahhh i dunno know man... i am only the driver! ask the man who built it :cheers:SC'dKellenersM5 said:abdulla....
what duration cams are you running now?
ahh shesh.. you are making all blush nowJayson said:Would it not be better to ask the man that built your car what he thinks. But **** I guess it's just never enough right :1:
Black M5 said:Good idea Rob.. he for sure needs it and the man who built mine could easily help him out :cheers:
ahh shesh.. you are making all blush nowhehehe just joking.. no honestly, with the highlift cams, shortshifting at 7000 rpm, 340 km/h dials which made the speedo go closer than it normally does... eventhough it was pulling nicely in the top end and 300 was no sweat... i just felt that maybe the diff will make it pull faster.... thats all hmmm
btw, since its a BMW... it realy drives extremely smoothly... not helping my butt meter either :crying:
BUT ... With the lower 3.45 Diff (instead of the stock 3.15) ... Abdullah's car will most definately get out of the hole much quicker ... so long as he can feather the clutch and prevent his tires from smokin' 'n burnin' up.Audioguy said:In my opinion I think you will see a decrease in real world performance...
With the kind of horsepower you are running traction is already an issue, and the new diff, would only magnify that. Being that the diff offers torque multiplication. Say for example with your existing 3.15 it takes "1" unit of HP to go "1" unit of distance in "1" second. With the new diff you'll see that "1" unit of distance in say ".8" seconds using maybe "1.2" units of HP. I hope that makes sense, I'm sure you know the basics of how the thing works, but my point is you've got enough HP to be able to use a "taller" gear ratio (3.15.) Using the 3.45 will give you the higher torque in turn making you accelerate faster at the low/mid end, but only up to a certain point. My theory is that for the mid/high range acceleration you're looking for, the solution is more HP, not just more torque.
-Audio
He's already got 800 plus hp.gra8fuldd ed said:BUT ... With the lower 3.45 Diff (instead of the stock 3.15) ... Abdullah's car will most definately get out of the hole much quicker ... so long as he can feather the clutch and prevent his tires from smokin' 'n burnin' up.
I feel strongly that by the time that having the lower diff (Higher numerical number) has a "Negative effect on his mid/high range acceleration" (as you call it) ... That RACE would be long over ! ! ! :M5launch:
PS ... I think that Vortech SC should give him ALL the HP he needs. AND ... If he still feel the need for more HP ... A little more boost & Fuel/Air or a shot of nitrous wouldn't hurt.
