1 - 20 of 95 Posts
I've been slacking for way too long. Here are the instructions on replacing the intake camshaft position sensor (problem discussed earlier in this thread)...
Disclaimer - I'm not a mechanic, nor will I ever be. Follow these directions at your own risk!! :rolleyes:
First, the problem...
The SES light was off and on for a few weeks. There were a number of different faults being thrown. I also noticed that occassionally, a deep low rumble would appear almost sounded like I had a hole in my muffler. After resetting the lights a few times, and trying to debug the problem I noticed that only two errors were constantly being thrown, MAFS fault and camshaft
position sensor (CPS) fault (with the CPS errors being thrown first). Since the CPS error was listed first and cheaper, I decided to replace this first. The error reported that intake CPS for cylinders 1-4 was possibly faulty.
Tools/Parts Needed:
* Intake CPS (also called a pulse generator) - Costs around ~$80 USD (dependent on where you buy it and various discounts; e.g. - CCA).
* O-ring - $1-2 USD
* Flat head screwdriver - medium size
* 5 mm allen wrench - I'm fairly certain this is the correct size
* Bright light!
* Small hands preferred
Time Required:
* Roughly 30 minutes. I could probably do it in 15 minutes after running through it once. Leave yourself one hour just in case. Make sure you understand what to do before doing it!! :)
Directions:
The following directions are provided for removing the intake CPS for Cylinders 1-4 (left side of engine when facing the front of the car). If you need to replace the intake CPS for Cylinders 5-8, the instructions will be the same.
Step 1 - Removal of the Airduct
In order to gain access to the intake CPS, you'll need to remove the airduct which connects the airfilter to the firewall. It's located at the top of the engine bay on your left hand side. Unfortunately, I don't have a nice pic with an arrow pointing to it.
First, you'll need to unhook five tabs connecting the airduct to the air filter box. There are three tabs on top (see three horizontal arrows in picture attached) and two underneath. Gently use your flat head screwdriver to pry them off. Once all five tabs are free you are ready to remove the airduct.
Using one hand grab the airduct near the base where it is connected to the firewall. Use your other hand to steady the rest of the duct. GENTLY twist/swivle the air duct upwards so that the part of the airduct connected to the air filter box is pointed upwards (The TIS instructions caution that using excess force could damage the firewall... bad thing to do!).
Once it's pointed, upwards, you should be able to easily pull the airduct out. Experience has shown that that removal of the airduct is much easier than putting it back in!!
Picture of airduct removed... the set of three yellow arrows on the right show the little tabs that are used to keep the airduct in place.
This picture is a closeup of the airduct and you can see how it is connected to the firewall. So removing it requires twisting and pull out towards you.
Step 2 - Locating the intake CPS
Once you've removed the airduct you'll need to find the intake CPS. The picture below aids in it's location.
Step 3 - Removing the connector
Here is are two pictures of the intake CPS removed. The 1st picture show how the CPS is oriented in the car (the screw is at the highest point). The second picture shows the bottom portion of the sensor and the old O-ring. The plug you need to remove is simply connected via a tab. Disconnect this first.
First pic...
Second pic...
Once disconnected, you can unscrew the single bolt (5mm allen wrench) used to keep the sensor in place.
Step 4 - Install new intake CPS
The BMW TIS instructions stated that you should first screw in the new intake CPS first but I found it easier to connect the plug first and then screw the intake CPS in place. Do what you feel is comfortable...
Step 5 - Putting airduct back in place
Once you've got the CPS sensor in place and the connector attached, it's time to put the airduct back in place. This is the trickiest part of the whole process. I recommend studying the tabs on the firewall and slots in the airduct (see above pics) a bit. Once you've understood how it fits, putting it back in is just a matter of patience. When everything lines up, it should easily twist back into place. I found that I needed to push the airduct in and
turn the duct back down to get it locked in place. Again... be GENTLE. Don't force the airduct to snap in... you don't want to break any thing.
Once the airduct has been locked in place to the firewall. Reattached the five tabs to the airduct. It should be fairly easy to lock each in place. If you got quite a bit of distance, then the airduct was probably not put back in correctly.
Step 6 - Test drive
When I test drove the car for the first time, it ran REALLY rough; lots of hesitation and such. I thought I had just trashed my car. :) I pulled over and waited a minute or so. After that no more hesitation and everything ran perfectly. You probably need to let it run idle for a couple minutes. SES lights never returned and I never saw the camshaft position sensor error again!
Notes - Replacing the intake CPS for cylinders 5-8 is a bit more difficult since there is not a clear path to the sensor. I'd recommend removing the right side airduct first and taking a look for yourself. If it's too difficult to reach then procedures are pretty much identical.
I've never written once of these TECH instructions before... if anything is confusing let me know and I'll try and clarify.
Thanks Johnny that is a great help!
although I've got a misfire on cylinder 5.. which I believe is on the other side, when I go to change it, I'll take some pics for comparison.
Thanks again. :cheers:
Tin
It's just a little bit more challenging on the right side... I should have taken a pic when I removed the airduct. I'll try and do that this weekend.
J
Ritter said:
84.500 KM not too much...way tooooooooooo much small s***** faults all time.. Bmw can't handle the electronics it's pretty obvious.. i''ll go for Audi anytime.. at least they can handle the electronics better
I'll go for 211 E55....may be...if have more money then NEW M5....
M5 Extraordinare!
Ritter, please watch your language... :nono:
Ritter said:
New M5 :7: It looks :crying: not a car i'll buy :cheers: it will have same problems as the old M5 hmmm
Hopefully it will have less probs...Other cars have some faults as well...but mainly mechnical...
Yes I agree with you from the cars I've owned M5 has the most probs...small and big....still annoying ouich...
Ritter said:
Aga..this should be solved before they relese the M5 cars on the market.. it's not proffesionally built..Engine & electronics..the rest i have no complaints.. very nice built ..perfect quality of the interior and carbody...it's up to perfection on those points a REAL kinggf of kinggf :S ...BUT Engine and electronics probs :crying: :nono:
I will still buy it...HOPEFUlly... :15:
Woogie Daxel said:
Go for Audi and see if you dont have electronic problems also.
If it is adressed to me, then, I had an S8 and it had far more less faults then an M5....plus I had an ALLROAD and less faults as well...
Ritter be careful
hmmm OUR HANDs ARE VERY LONG.... :nono: :7:
OK...how about instructions for the exhaust camshft position sensor?
:cheers:
Discussion Starter #17
:cheers:
I'll try and look into it... if I remember correctly, the exhaust CPS's are basically located in the same area except a bit higher on the engine block. For some reason I remember it being in a tough spot (for replacement purposes).
Banned
Dropped my Beast of at the dealer.. and guess what. The Computer readout said: Signal, Camshaft sensor, exhaust, bank 1 and camshaft sensor, bank 1, synchronisation to crankshaft.
Ordered the sencor, costs about $169 (Its Iceland and the government likes to take us for a ride with tarrifs).
So just like all you guys said, spot on dudes.
www.m5board.com ROCKS!
Banned
Just replaced my exhaust sensor on bank 1 (this DIY actually is for the exhaust sensor ;) )
It only took me about 10minutes to get the airduct out and replacing the sensor. But geting the airduct in was harder. Dont get mad if it does not slip in right away ouich . Just keep your cool and slip it into the slot. After many angry tries I took a breather. Then I looked at it again and tried, and it just slipped in.:cheers:
Now for the fun part.
Started up the engine without problems
Sound is quite different, not as deep at low revs.
Reving is easier, It just revs really quick in nautral
Power is amazing .. just over the top.
:noSMG: :wroom: :M5launch: :M5rev:
I tried to replace the intake CPS, bank 2 and it is next to impossible without some special tools (allen wrench). The exhaust on bank 2 is not that difficult, same for intake/exhaust on bank 1. Conclusion is that if intake CPS, bank 2 needs to be replaced, call a BMW shop (mine is going in tomorrow after spending several hours last night with a lot of swearing...)
1 - 20 of 95 Posts
