1 - 20 of 44 Posts
Evolve
I smell evolve intakes ?
Reactions: douglas_ngo
Everyone and their mom is getting the Evolve intakes. :tonquesmilie:
Only other thing that is making me wonder is when I do extended warranty claims. With the RPi setup everything is very stock looking, but with this setup I would have to swap back and forth.
You guys are all way off base.
He told me the secret:
lolllllllllllll
AFE intakes as we all know they produce the most power :blink:
Discussion Starter · #12 ·
I got a laugh out of some of the responses. Thanks guys. Tony, I told you not to reveal my secret. LOL
Anyway no one got the right answer so far....It is definitely increase HP....
Here is another teaser picture on my other mods.
I know what that is. Looks like Doug is starting the rod bearing job. That's the vanos high pressure line. In fact I'm going to start my dad's M6 rod bearings soon too.
So, of particular note here is the part hiding under the plastic.
You can see the flex-to-hard pipe joint on the upper end of the hose, but there is another lower down hiding under the plastic. You will be surprised how much effort takes to flex that lower part in place on a new hose to the pump discharge. IMO, this "bolt-up stress" could be responsible for some of the failures on these. It seems the hard pipe portions could have been pre-bent a little better to relieve this, but given you have to insert it in a small hole from the top may have precluded that.
Take care installing it, maybe over-flexure of this during initial engine builds led to the failures. Either way...take lots of pics.
I know what it is, but I'm not telling hiha
Maybe Randy sold his to him :3:
Discussion Starter · #19 ·
This last picture will probably give away the answer. The beast does not need more air...this filter should do the trick.:7:
1 - 20 of 44 Posts
