1 - 20 of 25 Posts
Hey guys ive been doing some research lately and thought about swapping the engine from an M5 or M6 into a 335i body, ive seen Hartge do the same thing with the E90, so I thought why not instead of picking up the M6 do this instead, will be truely Unique. Right now I am in the process of finding an engine from a crashed up 5/6, if anyone knows someone or a junk yard with one around pleae send me a pm.
There are auctions that insurance agencies use when car are totalled. If you are serious I would call some major carriers like Allstate, Geico, Farmers etc and ask them who they use for auctioning off totalled cars.
Why not build the 335 would be MORE of a killer than putting the V10 in it...i emagine one could pull 600hp from the 6cyl with aftermarket turbos and some engine work....easy.
And why not use an Xi for even more of a killer car.
Why do something that will do nothing but soak money? Girls don't really care what's underneath the hood.
I'd rather just buy an m6... it looks better more comfortable and its an M6... no one will know u have a v10 engine from m5 or m6 unless u tell them... id just buy an m6 thats just my opinion
Agreed... I would imagine putting the V10 under the hood of a E90/E92 would also require some (costly) structural modifications to accomodate the much larger engine (like moving the firewall for one).
Discussion Starter · #11 ·
I think many people are dissuaded by the complex electronic hurdles that will need to be jumped and the loss of warranty. I imagine that even an engine from a junked M5/M6 will cost a pretty penny. Are you planning on putting SMG in as well?
ofcourse the SMG will also be put in with the engine
Discussion Starter · #12 ·
i will keep you guys updated within the next couple days on the cost and what has to be modified to swap out the engine and the other necessary modifications, I will come up with a price and that will determine if I will go through with this or not...ill keep you guys updated
Most people I talk with about the M aren't even aware it has a V10 - just some sort of special 5 series. I kinda agree that since it's been done and while quite fast, its aerodynamics aren't as good, so top speed suffers. Now, take an M6 and strip it down to bare necessities so its light, then we're talking about a FAST M car. Saw an E46 M3 at the ring like this - totally stripped down inside and stock outside, except the plastic windows and it was passing all sorts of cars up!
Build a KILLER 335xi for 1/2 that money........1/2 the weight it will walk all over the V-10 HANDS DOWN.
or just wait till the new Twin Turbo V8 is put into production, 400hp 450ft/lb stock and we know with the v6 that was highly under rated...and with simple flash/exhaust people are seeing 100+whp/wtq gains so it wouldnt be surprising to see the ttv8 hitting 500whp and 550wtq for very minor modifications...
Yeah, if costs, actual power output and a slightly lower level of modification work is a high priority for your project then upgrading the turbos is the way to go. but if having something exceedingly rare and having every car junky literally drool when you pop the hood is the goal then v10...simple as that. Do your math and then pull the trigger. :cheers:
Be sure to keep us us updated, sounds like a cool project either way you approach it.
a0
1 - 20 of 25 Posts
