1 - 7 of 7 Posts
Hello friends,
This forum has been awesome for doing maintenance on my 06 M5 daily driver.
Inspired by the sweet song of this V10 I’m building a project with a 26k mile donor S85 motor in my Superlite SLC Kit car
Well, I’m currently having a rough idle issue and a strong knock on Bank 1 (left side of the motor).
Check out this YouTube video of the sound.
I’ve already inspected the Vanos pump and replaced the internal Vanos line when I replaced the rod bearings. I’ve also bench tested the Vanos solenoids And they are clicking, but I’m not sure that is a valid test.
Im also running the engine on a stand-alone ecu - the Scs Delta 880. So I’m not sure if I can read Vanos codes haing
Take a listen and let me know what you think!
Wow, nice project!! What’s the weight on that?
Have you connected to the computer?
How were the bearings?
Did you do a compression test?
Thanks sir! Projected weight is 2500-2700 lbs for the project.
The Delta ECU can be controlled with SXTune software and I have used that to monitor the engine.
The bearings looked fine, no major wear.
A leak down test on Cylinder 1 showed 12% loss, but I haven't done the whole engine.
That’s gonna be fast!!
So, running a different ECU means you don’t have the regular access to errors and testing options?
Cause it sounds like it would throw misfire codes with something else associated.
It also sounded like a broken valve spring that’s why I asked if you checked compression.
Listening to videos is always difficult
I found the Vanos settings for my ECU in the sxtune software and I was able to check the Vanos Position from 500-1500 RPM and Cam 1 and Cam2 Vanos were unresponsive. Tonight I will tear down the passenger side head and see what I can find!
1 - 7 of 7 Posts
