1 - 13 of 13 Posts
I just picked my car up this wknd and even during the test drive I noticed too much wind noise from the sunroof when visor is open. Is it common for the seal to wear. I have an 06 70000kms. I will be taking it back to the dealer to correct the issue but wanted to know if this is common
thank you
Absolutely. I have replaced mine twice, and the one on my previous E60. New seal makes a big difference if it is done correctly. There is still a faint whistle with the shade open, but it is not annoying. Its not that pricey to replace.
I had mine covered under a service bulletin.
Any info on this? Is it a big enough issue that they extended the coverage past initial factory warranty?
My wind noise is terrible, would love to get this fixed if I can.
Mdyaman has you covered. That's the one. :cheers:
Nice! thanks for the great info guys...my newly purchased e60 has terrible wind noise...i guess the service bulletin should cover it. I'll have my SA look into it.
use the search feature! and/or google! :typing:
SI B54 04 09 "Special Roofs March 2010 Technical Service" with a subject of Wind Noise or Water Leak from Sunroof. It covers a variety of vehicles including E60s produced up to 11/2008
http://www.m5board.com/vbulletin/e60-m5-e61-m5-touring-discussion/194243-air-noise-moon-roof-08-m5.html
PDF document attached.
Thanks there buddy :cheers:
I only asked because the dealer told me they would not replace it. I searched for sunroof, guess that's why this thread didn't come up :tonquesmilie:
Hey guys,
Just replaced mine the other day. Cost was $29 at my local dealer for the part, and it is an easy DIY. If you aren't sure how to do it, I found a thread over at Bimmerfest, seen here: E60 Sunroof Seal Replacement DIY - Bimmerfest - BMW Forums
Also, the service bulletin says the car must be RECODED after a seal change. That is not exactly necessary. This is because when closing (going from position tilt-up to tilt-down), the anti trap mechanism is triggered with new revision seal. You DO NOT need a computer to do this. Rather, just perform the in-car sunroof re-learn procedure, also shown at the end of that thread, and seen here:
<iframe width="560" height="315" src="//www.youtube.com/embed/z9AAks_lBlc" frameborder="0" allowfullscreen></iframe>
Hope this helps! Best $29 ever, car is pin quiet now!
1 - 13 of 13 Posts
